rear wheels not centered
I have a shortbed crew on a lengthened76 suburban chassis. The rear wheels need to move foward 1" to be centered in the guards. It has a longer hanger at the back and a small notch in the bed cross member. I'm trying to find out what is the easiest way to move the diff forward. Can you slide the lower leaves forward or are they all pinned together. The front leaf mount bracket is welded to the chassis.
Re: rear wheels not centered
Don't know what the "Easy" solution is, but if you move it forward you'll need to shorten the drive shaft as well. Worth it? Hmm!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
Shortening the drive shaft is no problem. It just don't look right with the wheels not centered!
Remove the rear axle and drill a new hole on the spring perch 1in off the center hole. That's the easiest way to move the axle.
John 82 Chevy Silverado 350ci/TH350
yes that
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
What about ORD zero rates?
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
they add an inch of lift
thanks John, that sounds alittle easier than cutting and moving the front mount!
| Bookmarks |
