A320 Pilot/USAF Retired
GMC park light rebuild question.
Just picked up a 55-56 GMC grill and need to do a little rehab on the park lights. It looks like I got two different types, one is a single element and the other is dual. We all know GM was good about using parts on many models and was hoping someone would know a cross reference for these.
Also need the lens mounting screws and a couple of "j-nuts" to mount the mustache. Thanks!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
Re: GMC park light rebuild question.
one is just a park light while the other is a park light/turn signal. Unless you are just bent on using those sockets or that type of socket you can probably find some universal park/turn sockets at the parts house that will plug and play with maybe just a little fiddling with them.
Check these guys out for hardware and clips. I think they have electrical pigtails and such too.
http://www.restorationspecialties.com/Products.html |
GMCDAC
I've got 2 on my '55 and 2 spares, all use the 2 contact socket that allows the 1157 type bulb. I can't help with a cross reference of what else may work but I'm sure something is out there. If you found another socket you sould be able to carefully un-crimp it from the bolt bracket and install the 2 contact one. I think the side pin locations are different in those 2 types of bulbs? I had a pair of those lense screws but sent them to BBPanel a month or two ago.
The j-nuts should be found at good hardware stores or where Cape Codder recommended. DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
Not GMC but I had the same issue with my 59. Here is what i did:
http://67-72chevytrucks.com/vboard/s...&postcount=685
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Thanks for all the info guys! I'll get out and look for a replacement and rebuild them for sure!
A piece of tin foil glued inside the housing will brighten them up if the housings are dull too. Think of shiny reflectors in modern tail lamps.
