Old 05-18-2014, 09:46 PM   #1
jammer3096
play in steering shaft
I've got alittle play in the steering and it seems to be coming from the steering shaft. I have replaced the gearbox replace the rag joint installed a collapsible steering shaft and have an aftermarket tilt steering column. its very noticeable driving down the road. it has the DD universal joint. Its not the alignment.
jammer3096 is offline   Reply With Quote
Old 05-18-2014, 10:25 PM   #2
brian1971
brian1971's Avatar
Re: play in steering shaft
Have you checked or replaced your inner and outer tie rods,I replaced mine when I purchased my truck and it took a lot of the play out of the steering.
Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 05-18-2014, 10:27 PM   #3
jammer3096
the front components are all new
Old 05-19-2014, 09:54 PM   #4
jammer3096
Any other ideas anyone has?
Old 05-19-2014, 09:56 PM   #5
jammer3096
I also heard if you're using a universal joint on the steering shaft you need some sort of bracket. anyone else heard of that
