Old 05-18-2014, 11:33 PM   #1
glen86
lowering shackels
Hi got question was thinking bout just doin shackels in the bk to lower it down a lil on my 86. Without the different brackets will I have clearance issues with the bed cross member above it and if so could I cut it out with out having problems with the bed loosing strength ?
glen86 is offline   Reply With Quote
Old 05-19-2014, 12:19 AM   #2
tinydb84
tinydb84's Avatar
Re: lowering shackels
You can cut the bed. I wont hurt anything. You can plate it back in but I would worry about it. You can do the hangers instead and not cut anything. FYI your pinion angle will change and may (or may not) cause some issues.
David
Instagram: myfabguy
Old 05-19-2014, 09:16 AM   #3
glen86
Thanks for the tips
Old 05-19-2014, 09:54 AM   #4
MalibuSSwagon
I was going to go the drop hanger kit from Western Chassis, the 4" drop with front hanger and rear shackles. Will this affect my pinion angle?
MalibuSSwagon is offline   Reply With Quote
Old 05-19-2014, 10:42 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Simple answer is YES. However, you can add a shim to get most of it back.
Frank
piecesparts is offline   Reply With Quote
Old 05-19-2014, 09:33 PM   #6
bigd65
bigd65's Avatar
Has not caused a problem on my 87. I have thee shackle and hangar
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 05-19-2014, 09:42 PM   #7
tinydb84
tinydb84's Avatar
Not if you do both hangers and shackles as they lower the front and back of the spring the same.
David
Instagram: myfabguy
Old 05-19-2014, 09:55 PM   #8
MalibuSSwagon
Thats what I was thinking. Ordered the kit today
Old 05-20-2014, 10:47 PM   #9
nheller76
nheller76's Avatar
We'll take picks so we can see what it looks like going in!
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
