Old 05-19-2014, 10:05 AM   #1
ugly
ugly's Avatar
Door rattle?
I can't seem to stop my passenger door from rattling like mad. It hits the rocker sill and has removed paint. If I move the hinges up, the body lines don't match.
Are there shims that go into the latch area to keep it from moving? Maybe something on the sill?
Any help and photos would be appreciated.
ugly is offline   Reply With Quote
Old 05-19-2014, 07:25 PM   #2
Jdubs71
Jdubs71's Avatar
Re: Door rattle?
This link covers converting truck doors into blazer doors so its a bit off topic, but there are good pics that show the different parts of the door. It may help you figure out if you're missing something.
http://67-72chevytrucks.com/vboard/s...d.php?t=273729
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 05-19-2014, 08:16 PM   #3
Special-Ed
Special-Ed's Avatar
Re: Door rattle?
sounds like messed up hinge pins or hinges
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 05-20-2014, 01:05 AM   #4
ugly
ugly's Avatar
Re: Door rattle?
Great link! That has the info I was looking for. Thanks.
My hinges may be suspect, but I am missing the top brass plates for sure. Gonna check LMC.
Old 05-20-2014, 10:40 AM   #5
ugly
ugly's Avatar
Re: Door rattle?
Anybody know where to get the brass plates for the door and jamb?
Old 05-20-2014, 10:41 AM   #6
ugly
ugly's Avatar
Re: Door rattle?
Or this one?
Old 05-20-2014, 12:03 PM   #7
sockalaminski
Re: Door rattle?
Check the body bushings as well. If they are worn or loose, they will allow the body to flex and rattle.
sockalaminski is offline   Reply With Quote
Old 05-20-2014, 02:27 PM   #8
Jdubs71
Jdubs71's Avatar
Re: Door rattle?
Keep checking the K5 parts board. You can also put a want to buy ad in the wtb section. You may have to be a paid member i believe, but could be wrong.
My build thread
Old 05-20-2014, 04:27 PM   #9
Bentblazer
Bentblazer's Avatar
Re: Door rattle?
Early model camaros and chevelle convertables use them OPGI sells them
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 05-20-2014, 08:20 PM   #10
ugly
ugly's Avatar
Re: Door rattle?
$47.00 Door alignment wedge
http://www.opgi.com/cutlass/1969/doo...inges/CH24776/
Bam! Thanks for the heads up...
Old 05-21-2014, 05:36 AM   #11
skorpioskorpio
Re: Door rattle?
I was going to ned these and I knew they wern't unique to the Blazer/Jimmys, thanks for posting a link. BTW OPGI says 2 sets left in stock (was 3 )
skorpioskorpio is offline   Reply With Quote
