Old 05-19-2014, 12:11 PM   #1
smallarm
HELP!!! - 1964 C10 Dash Color Code
Hello Fellow Members;
Hoping someone can point me in the right direction as to what the color/manufacturer/ paint code is for my 1964 c10 dash. Looks to be a beige type color, but I need to the exact paint code. I'm restoring, and want to repaint it in it's original color.
your help is always appreciated.
smallarm is offline   Reply With Quote
Old 05-19-2014, 01:24 PM   #2
1963c-10
1963c-10's Avatar
Re: HELP!!! - 1964 C10 Dash Color Code
Its called fawn. PPG 22151 seems to be the closest match
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-19-2014, 01:28 PM   #3
cg285
you can google it and get an original code. the last 2 times i had it mixed the ppg store could only formulate it in lacquer so i had them mix up a 1/2 pint and they color matched it from that into a single stage -(if that's what you want to use).
i used a flattening agent with it
cg285 is offline   Reply With Quote
Old 05-19-2014, 01:51 PM   #4
1963c-10
1963c-10's Avatar
I think 528 Fawn was the original code....
Old 05-19-2014, 11:33 PM   #5
smallarm
1963 C-10,
Thanks for the info. Much appreciated!
