05-19-2014, 01:18 PM | #1 |
hood springs
when I pull the hood latch on my 69 the hood doesn't pop up it has new hood hinges do you think I need new springs also anyone have this problem thanks
05-19-2014, 05:12 PM | #2 |
The Older Generation
Re: hood springs
05-19-2014, 11:20 PM | #3 |
Re: hood springs
Before you try new springs, adjust the rod that goes into the latch, and the two hood stops on either side of the grille. Also, it's possible the springs aren't aligned right. The alignment of everything should provide enough tension upward so that releasing the latch pops the hood up.
I had the same problem and it wasn't bad springs.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
05-20-2014, 10:48 AM | #4 |
Re: hood springs
Putting my truck back together and noticed same thing with hood. Pulled latch lever and hood unlocked but barely lifted.
Then I put in 4 new rubber bumper guides at sides between hood and fender and hood pops up a little more. Then installed new rubber strip between cowl and hood and now hood pops open nicely. Got lucky I guess. Hope the same for you. Serge |
