05-19-2014, 10:00 PM | #1 |
truck or camaro
I'm going to put a 700r4in my truck. My question is. Is it better to go with a 700r4 out of a truck or a Camaro? (short tail housing or long) My truck is a 67short bed. Thanks in advance guys!
05-20-2014, 12:49 AM | #2 |
Re: truck or camaro
Make sure the transmission is made after 1988 I believe. There were improvements made to them. Unless you are getting it rebuilt, then it wouldn't matter. If you're considering a 1 piece drive shaft the longer tailshaft would be beneficial.
05-20-2014, 06:57 AM | #3 |
Re: truck or camaro
On the 700 there is only one tailshaft. Unless you are counting the 2wd 4wd thing. It is true the closer to the model year 92 trans you can get the better off yor gonna be as far as improvements inside the case and to the case. Jim
05-20-2014, 07:42 AM | #4 |
Re: truck or camaro
Yes, 700R4 has only 1 length. You are better off with a truck/van tailhousing for mounting. Late '87 up is the one you want, it will have the improved pump and better guts. Corvette and Police car cores are also slightly better, but not enough to chase one down.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
05-20-2014, 09:09 PM | #5 | |
Re: truck or camaro
Sam |
05-20-2014, 09:44 PM | #6 |
Re: truck or camaro
I'm going to look at 1 out of a 89 Camaro tomorrow. They only want a 100 bucks for it and for that price my friend is a mechanic that specializes in trans so I can afford a total rebuild before installed at the price.
05-21-2014, 07:57 AM | #7 |
Re: truck or camaro
Some good info. in this thread. I guess that is what this board is all about.
05-21-2014, 08:22 AM | #8 |
Re: truck or camaro
My case was from an "86 Camaro", but it was rebuilt with the upgraded stuff. It's probably 12 years old now (the rebuild) with 35-40K miles on it. Fun set up with a 350 and 3.73 rear end. Just get the set up right and it will last a long time. Incorrect set up is what kills a lot of these transmissions in classics.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-21-2014, 08:33 AM | #9 | |
Re: truck or camaro
05-21-2014, 09:02 PM | #10 |
Re: truck or camaro
Well I went and looked at the tranny this evening and brought it home, it has the rainbow that luvbowties was talking about, not sure what the rainbow means. The oil doesn't look or smell like it's burnt but it looks good and used. The kid didn't know how many miles were on the tranny but that it came out of a 89 Camaro.
05-21-2014, 09:35 PM | #11 |
Re: truck or camaro
I am getting a 700r4/4L60 out of a 92 s-10 blazer ( 4.3 v6 2 wheel drive) a guy is parting out for $150. going to put it in a 68 lwb behind the 250cid.
I am getting converter, transmission, driveshaft, and all the tv cable brackets. I hope it is a easy swap.
66 c10 Panel (Wife's) http://67-72chevytrucks.com/vboard/s...d.php?t=595684 68 c10 LWB |
05-21-2014, 09:37 PM | #12 |
Re: truck or camaro
From the title, I thought you were going to ask us to choose between the two vehicles. I choose both:
05-21-2014, 09:39 PM | #13 |
Re: truck or camaro
As long as its not the 4L60 because they have electronics and the way I understand you'll have to use the computer to get the tranny to shift right. I hope someone will correct me if I'm wrong.
05-21-2014, 09:40 PM | #14 |
Re: truck or camaro
05-21-2014, 09:46 PM | #15 |
Re: truck or camaro
I like the 80s Camaros and Pontiacs, to bad you have to smog them here in comifornia.
Kirk 72 Blazer CST 4wd highlander |
05-21-2014, 09:48 PM | #16 |
Re: truck or camaro
Not sure if it is the 4L60E... 92 was the change over year from what I understand.
Guess I will find out when I go get it..LOL I think they make a aftermarket stand alone connection switch to activate the Electric controlled. guess i need to go read over on the drivetrain thread..
05-22-2014, 03:00 AM | #17 | |
Re: truck or camaro
Good luck on it having that case; and luck on it working well, as is. DON'T FORGET TO ADJUST THROTTLE VALVE CABLE CORRECTLY BEFORE DRIVING--IT IS NOT A KICKDOWN CABLE, BUT RATHER A "HEART REGULATOR" THAT ELIMINATES "HEART ATTACKS" ON THESE TRANNIES. IF RUNNING A CARB OTHER THAN A QUADRAJET, IT IS A MUST TO USE A CARB-LINKAGE-ADJUSTER[GEOMETRY-CONVERTOR] FOR THAT CABLE TO HAVE CORRECT GEOMETRY FOR OPERATING CORRECTLY. Sam |
05-22-2014, 09:22 AM | #18 | |
Re: truck or camaro
Research http://bowtieoverdrives.com/index.shtml and check out the TV made EZ TV cable kits and electronic lock-up kits with a brake switch (unlocks converter when you slam on the brakes.) I've been using their kits since 2006. Trans shifts great.
05-22-2014, 01:03 PM | #19 | |
Re: truck or camaro
