Old 07-31-2003, 10:18 PM   #1
doc70sub
doc70sub's Avatar
C-1500 + K-5 = 2wd to 4wd conversion
Hey Guys!
I own a '79 K-5 Cheyenne w/ a sour body & a great runnin '74 GMC Sierra Grande C-1500 w/ an original 454/TH-400 w/ A/C....going to combine the two to end up w/ a '74 GMC 4wd pick-up.
Either during the conversion or after, I'm going w/ a 14-bolt rear out of a C-20. Since it started as a 2wd, shouldn't the shock mounts & all related hardware bolt up?
She's going to start as a mall cruiser for a while, due to not having a transfer case & front driveshaft for a while. Will the 2wd rear two-piece driveshaft work w/ the 4" lift & using the 4wd frame mounts?
Thanks!
Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
