07-31-2003, 11:00 PM | #1 |
rad. support question
Ok, after i finished fixin the rust on my radiator support(kinda tacky lookin) i was out at my grandpas boneyard lookin through some stuff and see a 67-68 grill so i grab it and it still has the rad. support on it, and it is in perfect shape(close enough for bein in kansas) has the battery box and everything, so my question is, how hard is it to make the 67-68 work on my 70, i know i gotta cut off the headlight buckets and weld them back on, but is it very hard????
thanks kevin
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
07-31-2003, 11:42 PM | #2 |
Navel Inspector
That would be one I am needing to buy from you . As far as making it work on yours I only wish I knew. Someone is bound to have some answers though. Goodluck.
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
08-01-2003, 08:58 AM | #3 |
Mike
I assume it is a chevy?You will need to change fenders to 67-68 and also need the hood.67-68 are different from 69-72.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
08-01-2003, 07:15 PM | #4 |
member #16
Just take good measurements off of the old one before cutting them off. I used a spot weld drill to remove them. I took horizontal ,vertical and diagonal measurements and they fit perfect first try. I also fastened them with self tapping screws in case they needed to be moved. You wont know how the fit is until the grille and headlight doors are back on. Good Luck John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-02-2003, 01:32 AM | #5 |
ok thanks, so will the 70 grill and fenders and such bolt on????
