05-20-2014, 11:56 AM | #1 |
Wheel Hub 1970 Chevy Blazer
I know I am always posting questions... I hope one of these days to be able to read something and actually help you guys as well...
I discovered this weekend that one of my wheel hubs is bad. The knurled openings are worn and the lug studs won't seat correctly, if at all. A buddy wants me to weld the studs down, but the way the hub and the rotor sit together, I'd be welding the lug studs to the back of the rotor and have to break the weld if I ever have to change the rotor. I'd rather just get a new hub. (tonight I going to check and verify that it is the hub and not the knurl on the lug studs) I have a Dana 44 front end that was converted to disc brakes. Of course I discovered this once I had everything back together and when to tighten the lug nuts and they just kept spinning and spinning... Below is my setup. Does anyone know where I can grab one? I found what I need on RockAuto, but when I went to buy it, it said it was no longer available. |
05-20-2014, 12:01 PM | #2 |
Re: Wheel Hub 1970 Chevy Blazer
Bought mine at Napa.
05-20-2014, 01:06 PM | #3 |
Since this was a conversion, I do not know if it was a conversion kit, or if this was taken from a 1972 Blazer... my front axle is the original dana 44.
How did you determine what you needed? What I keep finding that looks the same all fit 1977 or later. Like this: http://www.raybestosbrakes.com/magno...artNumber=4945 |
05-20-2014, 01:39 PM | #4 |
One of the First
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
05-20-2014, 01:43 PM | #5 | |
05-20-2014, 02:24 PM | #6 |
Here is some part# info I found on a site that may help you identify what you have.
1973: 603374 1974-1975: 603454 1976: 603675, 603706 (also early 1977. These have wheel hubs with 3-1/8" diameter inner races) 1977: 603792 (mid to late production. Wheel hubs have inner races that are just under 3-1/4" diameter ) 1978: 610036 1979: 610054 Last edited by sockalaminski; 05-20-2014 at 02:31 PM. |
05-20-2014, 04:56 PM | #7 |
If i understand correctly whats up
i would spot weld the stud to the rotor and not think twice put the lug nuts on and seat them good and let the metal flow |
