Old 05-20-2014, 12:59 PM   #1
RRR18
RRR18's Avatar
Question Front End Conversion Year?
Just put new front wheel bearings and seals last weekend. Need some help for future reference. Front end is only thing I haven't rebuilt on my '67. Previous owner or someone put disc on front. Bearings were found to be for HD rotors. My '67 has 2" CPP drop springs (found # on em) and Chassis Tech drop spindles (unsure of drop amount no numbers). The upper control arms have bolted on ball joints.
Sooooo....How do I tell what year of parts I currently have on truck so I can buy in future when they wear out? I bought the bearings for a '75 but found those crossed with a bunch of other years.
I'm guessin I have mostly a 73-87 setup but I'm not for sure. How to tell? Give me any and all info. Thanks
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 05-20-2014, 06:20 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Front End Conversion Year?
With the information you gave, its a bit hard to know exactly what you need as there are alot of options within the same parts listed....
Wheel Bearings - you stated that you used '75 model HD bearings. This leads me to you have 1 1/4" thick rotors. If so, then any year '73-'87 with the 1 1/4" rotor wheel bearings work.
Ball Joints - This can be tricky...All upper ball joints from '63-'87 trucks bolt into the same mounting pattern as you described. Question for you: Does your Upper and/or Lower A-arms have rubber bushings or steel bushings? Rubber bushings started in 1973.
Outer Tie rods - This can be tricky too...many companies sell drop spindles that are year specific and that effects the ball joints and tie rod ends.
Some pictures of what you had could/would be helpful for others to help you get the info you are looking for.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-20-2014, 06:47 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Balljoints, tie rods and spindles all have to match.
73-87 would all be the same.
Bearings will be rotor specific.
Just like the calipers.
1" light duty or 1-1/4" HD rotor width.
Keith
Convert to disc brakes.
Old 05-20-2014, 06:48 PM   #4
lolife99
lolife99's Avatar
Pics of your suspension would also help.
Keith
Old 05-20-2014, 08:32 PM   #5
RRR18
RRR18's Avatar
Pics wil follow. Later or tomorrow. Thanks for help.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:06 AM   #6
RRR18
RRR18's Avatar
Ok here comes some pics........hopefully...........
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:09 AM   #7
RRR18
RRR18's Avatar
1.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:11 AM   #8
RRR18
RRR18's Avatar
2.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:13 AM   #9
RRR18
RRR18's Avatar
3.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:14 AM   #10
RRR18
RRR18's Avatar
4.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:16 AM   #11
RRR18
RRR18's Avatar
5.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:17 AM   #12
RRR18
RRR18's Avatar
6.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:23 AM   #13
RRR18
RRR18's Avatar
I'm guessing I've got 73-87 rotors, calipers, and pads.
I know I've got HD rotors.
No idea of ball joint or tie rod year(s).
Guessing stock year control arms.
Guessing stock year match for the Chassis Tech (no part #'s) drop spindle.
Educate me.
'67 BAD IDEA
Ryan
Old 05-22-2014, 11:33 AM   #14
lolife99
lolife99's Avatar
Educate me.
Looks like the original '67 crossmember.
A-arms could be 67-70 or 71-72.
Steel brake line routing is on the front of the crossmember, which means 71-72.
My "guess" is 71-72 drop spindles.
The ONLY WAY to know for sure,... is to verify the UPPER ball joint or the outer tie rod.
They will be either 71-72 specific,... or,... 73-87 specific.
Take one or the other to a parts store and verify what you have.
Keith
Old 05-22-2014, 11:50 AM   #15
RRR18
RRR18's Avatar
^^^ Much appreciated.....again lolife99.
If anyone is seeing anything else let me know.
Thanks.
'67 BAD IDEA
Ryan
Old 05-22-2014, 05:45 PM   #16
aggie91
aggie91's Avatar
Follow Keith's advice. I see the same thing...
Karl
The LST Challenge:
Old 05-22-2014, 07:30 PM   #17
michael bustamante
michael bustamante's Avatar
Guys... arent those slide on rotors? It looks like the lugnut studs arent pressed in the rotor
Im probably wrong but im just noting what I see.
1967custom
michael bustamante is offline   Reply With Quote
Old 05-23-2014, 09:59 AM   #18
aggie91
aggie91's Avatar
Nope, those are not slide on rotors. I have seen some with chamfers on that side of the rotor at the lug holes...
Karl
The LST Challenge:
Old 05-23-2014, 11:50 AM   #19
RRR18
RRR18's Avatar
Ya they're not slide on.
'67 BAD IDEA
Ryan
