05-20-2014, 01:16 PM | #1 |
ID front subframe
Hey gang,
I recently purchased a 58 Apache fleetside. It has a unknown front subframe under it. I am looking to purchase some new suspension parts but would like to nail down what exactly I should be buying parts for LOL. In some photos from searching online it looks like a 2nd gen Camaro/firebird subframe but the tie down points in the frame don't match up depending on the pictures I look at (the holes in the frame where the steering box bolts to). Any help would be appreciated! Here is the truck. Its a definite 20'er but I'll enjoy it. |
05-20-2014, 01:29 PM | #2 |
Re: ID front subframe
Maybe a Nova or other GM N-body equivalent from the 70's which would be almost the same as a 70's area front steer Camaro / Firebird
65 C20 292 4spd 4:56 Eaton HO52 |
05-20-2014, 02:06 PM | #3 | |
Edit: 76 Nova had a steering box up front, hard to find decent pictures though. Last edited by protour; 05-20-2014 at 02:22 PM. |
05-20-2014, 02:37 PM | #4 |
Nova, Camaro, etc are designated as X body.
Hard to tell from the pics, but the spindle doesn't look like X Body- maybe G (Monte Carlo)? |
05-20-2014, 04:22 PM | #5 |
Looks like Nova didn't get the front steer until '75. I thought it changed to front steer in '70 like the Camaro. Chevelles were always front steer thought
05-20-2014, 07:03 PM | #6 |
If you can find the casting numbers on the spindles, an internet search might get you there. Good Luck
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647 |
05-21-2014, 10:29 AM | #7 | |
Ill see if I can find some casting numbers on the spindles. |
05-21-2014, 11:08 AM | #8 |
Single piece spindles mark it as a 73 and up as the earlier Chevelles, Camaros and Novas had bolt on caliper brackets. I'm thinking 73/77 Firebird, Camaro or G body. The fatter sway bar may mean big block car or Trans AM, at least it looks fatter in the photos.
The way it is spliced is the way they did a lot of G body stub swaps.
05-23-2014, 09:25 AM | #9 |
Couple more pictures
The best I can get a measurement is guessing with a tape measure, roughly 58" hub to hub |
05-23-2014, 09:26 AM | #10 |
As you can tell the tires are flat, I have no air compressor and the floor jack wasn't working that is in the garage(not my garage)
05-23-2014, 11:11 AM | #11 |
When you said 58" hub to hub that made me think of G-body as they are 58" from wheeling mounting to wheel mounting surface but the upper control arms aren't arched like the G-bodies I have seen
05-23-2014, 11:52 AM | #12 |
yea I noticed that too. Im starting to think it is a 78 Nova clip... Off to the nova site to go through build threads hahah
