05-20-2014, 01:46 PM | #1 |
Where would I find a 1/4 inch sized funnel?
I intend to pour rust remover into my old truck's canister line (1972). Where would I find a funnel to fit into that 1/4" opening?
Can someone suggest an alternate method of getting this stuff into the removed canister line? |
05-20-2014, 02:01 PM | #2 |
Moderator
Re: Where would I find a 1/4 inch sized funnel?
Harbor Freight
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-20-2014, 02:03 PM | #3 |
Ammo reloading section of your local outdoor shop
1969 Chevy C10 2wd stepside longbox |
05-20-2014, 02:08 PM | #4 |
you could use and empty oil quart container with the taper spout that comes on gear oil containers. easy and cheap.
05-20-2014, 04:01 PM | #5 |
Syringe from drug store or Tractor Supply/CoOp
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
05-20-2014, 04:19 PM | #6 |
Proprietor of Dale's Corner
Flask funnel....they always need filling...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-20-2014, 09:54 PM | #7 |
try the old oil squirt can the one you push with your thumb on the bottom to squirt the oil out.......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
05-20-2014, 10:30 PM | #8 |
A sheet of paper and a piece of tape.
05-20-2014, 10:31 PM | #9 |
Go to the grocery store and look near the utensils and pots and pans. They usually have small plastic funnels there.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
05-20-2014, 10:41 PM | #10 |
Also, If you happen to own a ford with the stupid gas door/cap setup, the funnel near you factory jack assembly will fit ove the hose snug
05-21-2014, 10:23 AM | #11 |
X 2 Make it card stock and it'll work just fine.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
05-21-2014, 12:54 PM | #12 |
Probably should get a funnel made of the same material the rust remover container is. That stuff can be pretty nasty.
