Old 05-20-2014, 05:02 PM   #1
forestb
forestb's Avatar
Inner fender Mounting Grommets
I ordered a set of Inner fender Mounting Grommets (the rubber washer that goes on the hole in bottom rear inner fender where it bolts to the bracket that bolts to the cab) from Bowtie Bits. and they seem much smaller in diameter than the originals. Is this common? Do other companies sell the right size? They are much smaller than the mettle washer that goes around them.
Also when I took the original bolts out there is a mettle sleeve around the bolt. is that supposed to come off or is it part of the bolt?
forestb is offline   Reply With Quote
Old 05-20-2014, 06:39 PM   #2
cortcomp
cortcomp's Avatar
Re: Inner fender Mounting Grommets
ones i got from LMC were smaller too, curious what others say.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 05-22-2014, 11:55 AM   #3
forestb
forestb's Avatar
So nobody else has ever tried replacing these Grommet?
Old 05-22-2014, 01:06 PM   #4
1963c-10
1963c-10's Avatar
Ive got a set from classic industries two years ago....and they are still in the bag. I'll check mine tonight and let you know what I have size wise.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-22-2014, 02:47 PM   #5
forestb
forestb's Avatar
thanks
Old 05-27-2014, 01:48 PM   #6
1963c-10
1963c-10's Avatar
Sorry for the delayed response...I measured them before leaving on my trip Friday....the ones I have from classic industries are 1 1/2".
Old 05-27-2014, 01:52 PM   #7
cortcomp
cortcomp's Avatar
The original ones are like 2-2.5 if i recall correctly. I'm not quite to that part in my restoration, but i did notice they are smaller. I don't think it actually matters once installed though.
Old 05-27-2014, 02:18 PM   #8
1963c-10
1963c-10's Avatar
Looking at the conditions of my originals.....the repops will be an upgrade. I will measure the originals tonight though for reference.
Old 06-09-2014, 09:07 AM   #9
1963c-10
1963c-10's Avatar
Sorry for the delayed response.....I measured two sets of original grommets and they show 1 3/4" with the repops being 1 1/2"
Old 01-19-2015, 02:40 PM   #10
mcfarlnd
Bringing this back up. Anyone got a good source for grommets that fit correctly?
mcfarlnd is offline   Reply With Quote
Old 01-21-2015, 12:14 AM   #11
Andice
Andice's Avatar
Maybe this will help. It's been too long for me to recall the correct size required.
http://www.rubbertherightway.com/sc-grommets.htm
Andice is offline   Reply With Quote
