05-20-2014, 05:16 PM | #1 |
Need some 6 lug swap info
Okay so I'm wanting to 6 lug swap my truck. I've got the rear end figured out, but I'm needing help with the front. I read that you can get replacement '60-'70 rotors to go on the squarebodys as long as you have the 1 1/4 inch thick rotors from the factory. I only have the 1 inch thick rotors so whats My options now? Thanks!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
05-20-2014, 05:34 PM | #2 |
Diggin The SquareLife
Re: Need some 6 lug swap info
05-20-2014, 07:18 PM | #3 | |
05-21-2014, 03:12 AM | #4 |
Salty Sailor
hey have you seen my build thread? I did a 6 lug swap
im pretty sure its a sticky thread in the FAQ
86 c-10 Custom Deluxe Savannah, Georgia |
05-21-2014, 06:28 AM | #5 |
Need to swap spindles due to the bearing size, cheap in the yard, if you are going to lower it, just choose the right ones. You do need the conversion rotors and correct calipers (standard thick rotors). So if you have 'thins' you need rotors, dust shields, and calipers, plus the conversion rotors and bearings / seals.
This is not the place to cheap out. If you're going in there it would be wise to do the balljoints if they aren't fairly new, and shocks.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
05-21-2014, 08:22 AM | #6 |
okay, well I have a 1999 2500 parts truck, what all parts can I use off of it? I know I've heard I can use the spindles..
05-21-2014, 03:26 PM | #7 | |
Salty Sailor
you will need 3/4 ton lower control arms from a 73-87 truck
05-21-2014, 04:54 PM | #8 |
Okay thank you! I'll have to get rotors still cause the 2500 I have is 8 lug.. /:
05-21-2014, 09:24 PM | #9 |
I may just use the 8 lug stuff I have with these 8 lug steelies and be halfway done with the 6 lug swap... save up then go 6 lug.
05-22-2014, 12:06 AM | #10 |
Salty Sailor
be sure to post pictures!
