Is there a patch panel for the Inside roof on a '62?
Hey all just wondering if there is a patch panel available for the inside roof panel along the windshield? I have found the ones for the outside but none for the inside.
Re: Is there a patch panel for the Inside roof on a '62?
I see u need the outer also ,which they do repop ,but no on the inner roof section you will have to hunt down a donor like I did or fab it yourself. goodluck!
UCA63
Funny how they only make the outer. (Usually) when the outer's gone, so is the inner.
I managed a donor with totally toasted floors. T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) Last edited by 63sbssbbw; 05-21-2014 at 05:40 AM. Reason: sp. |
Removed outer panel and now have inside one to deal with. I am thinking about patching the inside roof panel with some fibreglass as i can access it now. Then attaching the outside panel and then filling inside the cab with long strand filler.
Or welding a piece on the inside of the roof panel and filling after...I am concerned about warping the inside roof panel and think fibreglass will work just as good. |
i did fiberglass on my 64 worked out good
Are the inner roof panels the same as 64-66?
