Old 05-20-2014, 06:50 PM   #1
jrigheimer
jrigheimer's Avatar
Sound deadening
How much sound deadening material will I need to cover the cab of my truck, the fire wall, floor, and back wall. I was looking at the dynamat bulk pack it comes with 38 sqft, curious if this is enough. Does anyone have any recommendations doing this, should I do the doors too and also should I coat my floor with a rust inhibitor or something like por-15?
jrigheimer is offline   Reply With Quote
Old 05-20-2014, 07:01 PM   #2
67ctener
67ctener's Avatar
Re: Sound deadening
My ball park guess would be 45sq ft. You can also find it by length x's width of back of cab, floor, and firewall. I would imagine 38sq ft would get you pretty close. Dynamat is a sound deadnear only it will not protect the metal other then just surface water/moisture wouldn't penetrate the underneath steel
67ctener is offline   Reply With Quote
Old 05-20-2014, 07:03 PM   #3
BC10
BC10's Avatar
Re: Sound deadening
I used Second Skin, here is a great deal on their B stock stuff.
http://store.secondskinaudio.com/b-stock-40-pounder/
With the 40lb stuff, I had a good amount left after lining my car. High quality stuff.
BC10 is offline   Reply With Quote
Old 05-20-2014, 07:13 PM   #4
MidLifer
MidLifer's Avatar
Re: Sound deadening
Have a read on www.sounddeadenershowdown.com before you embark on this project. What I learned there is that the "mat" products are vibration dampeners and that you only need to cover 30-40% of the meal area. The key is to add a layer of a product called mass loaded vinyl that actually blocks sound from passing through it.
This is yet another of those subjects on which we all have opinions and Im sure mine is different than a lot of folks here, but read that site and examine his data for yourself. I did and am very happy with the results.
MidLifer is offline   Reply With Quote
Old 05-20-2014, 07:20 PM   #5
davepl
davepl's Avatar
Re: Sound deadening
Sound deadener deadens the panels. It does not insulate against sound (well, not at the frequencies you care about). MidLifer is right. For example, on my back wall of my cab I put an insert of mat on each of the "low" stamped areas. No need to cover the whole thing.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-20-2014, 08:13 PM   #6
Tinkermc
Re: Sound deadening
I used Dynamat and did the roof also, I'm very happy with what I have.
Tinkermc is offline   Reply With Quote
Old 05-21-2014, 12:53 AM   #7
Z10
Z10's Avatar
Re: Sound deadening
Click on my build thread and you'll see what I dead. Dynamat type material down first, closed cell aluminum backed insulation, MLV mass load vinyl, carpet insulation then carpet.
Not hard to do, but it is time consuming.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 05-21-2014, 10:38 AM   #8
DUD2STUD
DUD2STUD's Avatar
Re: Sound deadening
To answer your second question yes it never hurts to Por-15 the floor before you sound deaden it
DUD2STUD is offline   Reply With Quote
Old 05-21-2014, 02:05 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Sound deadening
Take a look at the Lizard Skin web site.
http://www.lizardskin.com/
Frank
piecesparts is offline   Reply With Quote
Old 05-21-2014, 03:44 PM   #10
sambudo
sambudo's Avatar
Re: Sound deadening
My friend uses the product from homedepot in the roofing area. 60% cheaper and it wooks great for heat resistant and sound. I'll post the name of it if I can get a hold of him.
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 05-21-2014, 03:55 PM   #11
AirSpeed
AirSpeed's Avatar
Re: Sound deadening
Don't forget to do the inside of the outside door skin, makes a big difference in noise levels in your cab. It also sounds better when you close the doors, a nice thud instead of a loud clang
AirSpeed is offline   Reply With Quote
Old 05-21-2014, 07:32 PM   #12
BC10
BC10's Avatar
Re: Sound deadening
It's called peel and seal, and it is an asphalt based substance as opposed to dynamat and second skin which are butyl based. Second Skin has thicker foil material on the backing of it vs dynamat, but they are both equally good products.
Check this out:
http://www.sounddeadenershowdown.com
In my truck I have dampener and deadener in it, makes a huge difference.
Old 05-21-2014, 07:35 PM   #13
davepl
davepl's Avatar
Re: Sound deadening
Keep in mind if trying to use asphalt roofing stuff that the smell might be strong and hang around a lot longer than you'd like.
Old 05-21-2014, 07:57 PM   #14
Andy4639
Old member
Andy4639's Avatar
Talking Re: Sound deadening
I used road kill and very pleased with it. I did a 12" square inside the door and then 4" squares in each corner of the doors. They shut now with a nice thud sound like a new vehicle.
I also put the bubble wrap down then the carpet.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-21-2014, 08:38 PM   #15
chevy72blu
chevy72blu's Avatar
Re: Sound deadening
I used dynamat extreme in the doors and it made a huge difference, mostly with the stereo cranked (eliminated vibration in the doors from my 6x9s). I used LMC's sound damping kit in the cab with so-so results.
With my vent window rubbers shot, not much can be heard over the wind noise anyway... I need to take care of that soon.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-24-2014, 11:45 AM   #16
bigsnookmaster
bigsnookmaster's Avatar
Re: Sound deadening
I used second skin. I am very pleased with it! I put it everywhere I could, on the gas tank, underneath the dash,under the headliner, just about everywhere! Wherever you tap on my truck, it sounds like it's plastic. Very good stuff!
bigsnookmaster is offline   Reply With Quote
Old 05-24-2014, 01:46 PM   #17
TacBlade
Re: Sound deadening
The bulk pack is not enough. Doing mine right now. You will need about 4 more sheets.
TacBlade is offline   Reply With Quote
Old 05-24-2014, 02:03 PM   #18
Lee H
Lee H's Avatar
Re: Sound deadening
I used Dynamat and very please with the results. I did the entire floor from the gas tank up to the bottom of the cowl, behind the gas tank, cab corners, inside the doors. Very little road noise, loud exhaust and I can hear the radio on low volume even at freeway speeds. I bought the 9 piece set (72 square feet) and had one sheet left over plus the scrapes. There's a few pictures in my album.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-24-2014, 08:52 PM   #19
MVHandy
Re: Sound deadening
I used the peel and seal from home depot, two rolls of the 6 inch wide was plenty. That was two years ago and I have never had an issue with any sort of smell or other issues. If you look up the MSDS for dynamat and peel and seal you will find they are the same material, just slightly different thicknesses.
MVHandy is offline   Reply With Quote
Old 05-24-2014, 08:52 PM   #20
70cst
70cst's Avatar
Re: Sound deadening
I used B Quiet. I am very pleased and I got it of ebay with free shipping.
http://www.b-quiet.com/ultimate.html
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-24-2014, 09:10 PM   #21
Andy4639
Old member
Andy4639's Avatar
Cool Re: Sound deadening
According to the box it has 20 sq ft in each one and I used 2 boxes of it to cover the floor and up the back wall to the window and both doors and up to the fire wall in front. I left the factory stuff in place on the fire wall. I have 2 12" peices left in the second box. That would mean 38 sq ft is what I used. I didn't cover every inch of the floor are the back wall but I did a pretty good bit!
