Old 05-20-2014, 10:21 PM   #1
pritch
pritch's Avatar
Fingers crossed until I get to the gas station...
But I think I have fixed my gas gauge. It's had the 3:00 blues for several years now. I had a sender that tested good, and I figured it would be easy to switch them out. Not. I got the old sender out without incident, and the new old one in no problem. But when I went to hook up the gas line, they were different sizes of tubing. Maybe it's a 6 cyl/8cyl thing, or maybe a big block/small block thing, or maybe even a luck of the frikkin' draw thing, but no way it was going to work.
The one on the left came out of my truck, (original 6 cyl) and the one on the right, pulled from some long forgotten donor, is clearly larger:
So I pondered on this for a while and decided that I had to remove the float assy from the good one and intall it one the one that came out of my truck. I carefully cut them apart:
I thought about tack welding it back together, but decided that if I could find a couple small hose clamps that would be easier than dragging out the welder:
While I was at it, I stuck on a new pick-up sock. I know it looks bad, but it can't come off:
After all this, I reinstalled the whole scene and my gas gauge went to 3/8s of a tank
Actually, I thought I had more than that, but we'll see next time I fill 'er up.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 05-21-2014, 12:00 AM   #2
72chevyk10
I built it
72chevyk10's Avatar
Re: Fingers crossed until I get to the gas station...
good luck! the guage in my rig is accurate to within a 1/2 tank
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-21-2014, 12:43 AM   #3
King Cary
The gas gauge never worked in my old 64 GMC shop truck... Every other day I would just take the gas cap off and shake the truck and listen to the gas splashing around. If it needed it I would stop and put $20 in. It had a 455 Pontiac out of an older Trans-Am and it didn't miss too many gas stations...
King Cary is offline   Reply With Quote
Old 05-21-2014, 11:24 PM   #4
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
My gauge is way out of whack! So I use plan B. Crude but effective.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline   Reply With Quote
