Old 07-31-2003, 11:34 PM   #1
PloreOSU
Offset Camber Upper Shaft Source???
I went to have my front end aligned today, and the guy couldn't get the left hand side all the way into alignment. It still has a 1.8* positive camber. The mechanic suggested getting a negative 1.5* camber upper control arm shaft.
I can't seem to find these for our trucks, only for A-body cars and Corvettes. Maybe those would fit, but I'm not sure. Does anyone know of a source for these parts or have suggestions for different parts instead? Thanks in advance.
PloreOSU is offline   Reply With Quote
Old 08-01-2003, 10:09 AM   #2
slam33
slam33's Avatar
They don't make such a shaft, all the replacement shafts are the same design. You would have to get an aftermarket upper a-arm that is adjustable, maybe AIM has them. If your slamming the front, thats one of the problems you run into. If it's stock, them take it to another mech. I just put a new front end on mine, shafts/arms/joints/ect.ect. The guy at the alinment shop had no problem setting me up.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-02-2003, 10:09 AM   #3
loweredd
www.loweredd.com
loweredd's Avatar
What year is yours? Moog has them for 73-86, $44.54, pn #K6184, and for 87-91, $39.66, pn #K6355. This is for 1/2 ton.....let me know if you have something else.
loweredd is offline   Reply With Quote
Old 08-02-2003, 10:10 AM   #4
loweredd
www.loweredd.com
loweredd's Avatar
LOL, I posted exaclty 24 hours after slam33...
Old 08-03-2003, 12:12 AM   #5
PloreOSU
Sorry for the confusion, I apparently hid my sig in that post. I have a 72 GMC 2x4. We'll see if my sig appears this time.
Thanks for the help, I'll have to see if those part numbers will fit.
72 GMC, 2x4, LWB Fleet
DONE: 2/3 drop, 17" rims, front end rebuild, front/rear sway bars
Working on: old air AC, blazer tank, rear discs, 03 silverado seats.
Old 08-03-2003, 01:47 AM   #6
loweredd
www.loweredd.com
loweredd's Avatar
I will try to remember to check Monday.
