05-20-2014, 11:22 PM | #1 |
Adjust door hinges- sitting a little low
The doors on my 71 C20 sits just a tad low- if I lift it a little it closes fine. If I don't lift it, it still closes, but I have to give it a harder swing and it hits the bottom of the door frame with a loud bang before closing.
There is some vertical play, but not a significant amount.. I have to look closely to see it. Is there a way to just adjust the entire hinge and have it sit higher? Or do I have to get new door pins/bushings? |
05-20-2014, 11:33 PM | #2 |
Re: Adjust door hinges- sitting a little low
If you can move the outer half of the hinge by lifting up on the door, then replacing the pins would be a good idea. However, the vertical adjustment on the door is in the body half of the hinge. I've seen pics of a 'Special' wrench the GM put out for getting to the bolts behind the fender, but I've always just removed the fender.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
06-05-2014, 08:25 AM | #3 |
Does anyone know if these hinge pins will fit? : http://www.pepboys.com/product/details/714512/00192
They look right but not sure of the diameter. Anyone know? |
06-05-2014, 09:05 AM | #4 |
It looks different than GMC PAUL'S and I would trust his stuff over any of the national parts stores any day.
http://www.gmcpauls.com/pictures/doo...ndbushings.jpg
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
