Any Photos Of C-4 Being Put In C-10
Good Morning Everyone, I am trying to find some threads of someone that has put a C-4 Corvette suspension a 67-72 C-10 Truck. I am wanting to use the factory C-4 front cross member. I have looked and looked for someone that has done this and has some good photos and measurements of how they did theirs but cannot find any threads. Can someone lead me in the right direction! Thanks in Advance for any help!!!
Re: Any Photos Of C-4 Being Put In C-10
I'm no help, but when I read the title I thought you were trying to put a Ford transmission in your truck.....
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Or make it go boom
1969 Chevy C10 2wd stepside longbox |
I have the same plans. I have the complete front and rear suspension from a c4 corvette that I am going to install next winter. I ended up purchasing the front suspension cross member from Flat out engineering. All the front suspension bolts onto it once it is welded into the frame. For the rear I plan on using the rear frame rail kit from no limit engineering. That frame rail kit will convert the spare long box frame I have into a short box and also raise the rear frame rails up about 4 inches. That will give me more room for the rear suspension mounting.
Just another thing to add. I did see some pictures on the forum from a local shop that installed this front cross member. If I remember correctly I think it was called California custom hot rods in Aldergrove BC. I went out there to take a look at it. Looked good, they did some nice work.
#6 | |
http://www.flatout-engineering.com/products.html |
I dn't remember his name but here is a member doing this, saw a post with his outline about 2 months ago.
I'm just glad to be here!
Here is an OLD thread from Porterbuilt. I do not think he is making them any more, but he might be a goo resource.:
http://67-72chevytrucks.com/vboard/s...d.php?t=255981 I know there was a guy in Texas that did a '64-'66 truck with one, but I can't find his build thread right now. If I do, I will post it up. The frames are the same where the front suspension would mount and the rear needs to be something custom... Here is the '66 I was thinking of: http://67-72chevytrucks.com/vboard/s...d.php?t=284880 here is another for the rear from PBFab: http://67-72chevytrucks.com/vboard/s...d.php?t=203958 Another C4 in the front of an '83: http://67-72chevytrucks.com/vboard/s...d.php?t=389909 Hope those help...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 05-21-2014 at 05:37 PM. Reason: added link... |
There was a build thread of someone putting a 67-72 on a C5 chassis, torque tube and all. It was a pretty wild build. I'll poke around and see if I can find it
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
I think my timimg was off a bit but this will take you to the thread and it wasnot a Ford Transmission but a C-5.
Hideintire Registered User Join Date: Dec 2012 Location: Burgaw, NC Posts: 4 |
65 C20 292 4spd 4:56 Eaton HO52 |
#13 |
Thanks to everyone that replied to my not so good though out question. I will make sure that I read all of the post to get all the help and measurements I might need. I have installed a c-4 (corvette) front and rear suspension on a 1958 Corvette frame last summer and made all of the brackets for the rear end and also cut and used the factory front c-4 (corvette) cross member on it and the 58 sits good and handles great. I started my mock up of the corvette rear on the truck frame today b-4 I got home and read the replies. I am going to have to cut up into the frame to let the bat wing go up in it to get the ride height I want so these photos is not where it will set when finished. I would and will post some photos as soon as I learn how!! I am going to try!!
#14 |
Another idea I had was to remove the batt wing/cover assembly from the diff. Then get the guys at work to burn a 3/4 or 1 inch plate steel the same shape and bolt pattern as the batt wing but with a narrower batt wing so it would fit on the inside of the frame to mount it. Then just use a tin diff cover to bolt to that to seal it up.
#15 |
![]() Join Date: Apr 2007
This is the flat out engineering kit....i used this several years ago but sold before finishing...was doing an ls2 conversion and the front suspension kit from them was not correctly engineered (in my opinion...and i had many discussions with the owner) however the rear was very nice....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#16 |
Thats a pretty good ideal. I would like to see it if you get one cut out. It would not be that hard if a person had a CNC machine but I don't. I am going to use a piece of 6" channel and,cut it the width of the frame and put it up in the frame then plate it on both sides, something on the line of putting a C notch in the frame for the half shafts but wider and taller and then the bat wing bracket will go up in that, also this will let the ball joint on the rear end not hit the frame. Got in my head and am going to try and get it made and tacked up today!!
#17 |
I've been on the phone with flat out engineering. They do not have a rear kit for our year of trucks. They said its in the works but couldn't give me a date as to when it would be available.
#18 |
RIDGE CLIMBER, I am making everything I think I will need to install this front and rear C-4 suspension. I have got the rear in today and alot of the brackets tack in. The way I am doing it should give me 9" to 10" ride height with 18" wheels, and that will be fine I think. Did not take any photos of what I done today but I will be back in the shop Tuesday next week and I will take some. If you can just make your own stuff instead of paying that high price for someone else to build it!!
#19 |
I agree about making as much as possible. I am a heavy duty mechanic so its not that difficult, just take some more time. Take some pictures and keep us posted as to how your making out.
#20 |
![]() Join Date: Nov 2001
Ditto
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#21 |
cool thread.
I've been thinkin about building a c-4 truck
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#22 |
In my 68 I used the 55-59 kit from flat out ...very little mods....jim
#23 |
A Couple of photos of what I got done so far.
#24 |
A question for the guys that are following this thread. What are Dana 44 (4spd) rear end/suspensions selling for?
'67 GMC 2500, 292, 4spd, AC |
#25 |
Wide n'Low
![]() Join Date: Jan 2007
I know Frizzle Fry has this little gem http://67-72chevytrucks.com/vboard/s...d.php?t=179289
Maybe he can share some of his knowledge
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
