Old 05-21-2014, 11:44 AM   #1
rickoner
? for you guys that lay frame
For the guys that are bagged and laying frame, how did you do the front crossmember? This is for the guys that didn't go the dropmember route. I've read many build threads and there's a few ways to skin this cat. From Z'ing the frame to sectioning the the crossmember. How high did you have to raise the control arms to be above the bottom of the frame rail? I'm hoping to hear from personal experience what route people have gone and the pros and cons or if they would do it differently now.
rickoner is offline   Reply With Quote
Old 05-21-2014, 11:51 AM   #2
63 & 64 Bowties
and a few others
Re: ? for you guys that lay frame
Here's some reading to get you started:
http://67-72chevytrucks.com/vboard/s...hlight=xmember
you can do a search for pancake xmember or crossmember to find others.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 05-21-2014, 12:57 PM   #3
tinydb84
tinydb84's Avatar
My 66 has a 2 inch sectioned crossmember. The steering was converted to a later model power steering. The body mounts were moved down an inch for a stock floor body drop.
I have a one inch sectioned crossmember for sale in the classified section if you are interested btw.
David
Instagram: myfabguy
Old 05-22-2014, 06:57 AM   #4
Bomp
Bomp's Avatar
Mine is still a work in progress.
I was told, "don't be afraid to cut".
Bomp is offline   Reply With Quote
Old 05-22-2014, 11:07 AM   #5
tinydb84
tinydb84's Avatar
I really like this guy's build http://67-72chevytrucks.com/vboard/s...d.php?t=269019
David
Instagram: myfabguy
Old 05-22-2014, 09:12 PM   #6
hotrod66
hotrod66's Avatar
my friend channeled his cab 3 inches you can see it in this pic. when its down it lays rockers.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 05-31-2014, 01:11 AM   #7
rickoner
Well, I've jumped into cutting up a crossmember. Took out 2" and hopefully will have it all welded up this week. Thanks for the replies guys. Lots of different approaches out there, that's for sure.
For the people that have done the pancake, has anybody slid it forward when putting it back under the truck to help recenter the wheel? Is there a problem with moving the steering box forward too? Seems like it shouldn't be to big of a deal since you've got to reposition it up anyways.
Old 05-31-2014, 01:54 AM   #8
tinydb84
tinydb84's Avatar
What are you going to do about your steering?
David
Instagram: myfabguy
Old 05-31-2014, 02:32 AM   #9
rickoner
Well, in my mind I would like to go with a r&p setup, but my wallet is telling me that I'm going to stick with the p/s box that I have laying around. I have the section of the frame that the p/s box mounts to. I'm thinking that I could graft that piece into my frame so that it lands the box the 2" higher and 1" forward to keep the original geometry. Of course there'd need clearance for the linkage and have to use some heim joints for the column shaft too. This is just a thought that I have in my head right now. I'm thinking that once I have the crossmember up into place I'll be able to see if it's even possible. Sound like it's doable to you? If not, I'm open to suggestions.
Old 05-31-2014, 02:34 AM   #10
WCHLVR
WCHLVR's Avatar
2" Pancake
Stock Frame Bridge
Moved the steering up an inch. 75 C10 power box. S10 pitman. Frame notch for the ptiman.
A arm notch and custom linkage
WCHLVR is offline   Reply With Quote
Old 05-31-2014, 02:42 AM   #11
tinydb84
tinydb84's Avatar
^^That is how mine is done on my 66. I got it that way. I'd probably go with a Z had it not already been done
David
Instagram: myfabguy
Old 05-31-2014, 03:07 AM   #12
rickoner
Looks like a nice setup. Does raising the box only 1" cause any problems? Is there a reason for not raising it the 2" to match the crossmember? What's the deal with the s10 pitman arm? Is there an advantage to using it?
Why would you go with the z? Is there something about the way yours is done that you don't like?
Old 05-31-2014, 03:18 AM   #13
WCHLVR
WCHLVR's Avatar
Z is a solid way to get it laid out. Personally I hate the idea of moving the engine up and messing with floor of the truck. Thats just me though.
Thanks. Pretty pleased with how it has turned out. You can't move the box up a full two inches because the harmonic balancer will hit the center link. The S10 pitman is much flatter than the C10 counter part. The profile is a much closer match to the stock idler arm.
Old 05-31-2014, 03:38 AM   #14
tinydb84
tinydb84's Avatar
I have sectioned a crossmember:
and doing that plus moving everything up and notching is a lot of work for only 2 inches. Then move the body down to get rid of the frame.....It was already done when I got the truck (I still need to do some finishing work on it) so I'm not complaining.
This is my first Z (still working on it) and doing a sfbd as well to lay rocker.
(I included a bunch of pics of my work and trucks because everyone loves pics )
David
Instagram: myfabguy
Old 05-31-2014, 03:39 AM   #15
tinydb84
tinydb84's Avatar
WCHLVR - Good looking truck btw!
David
Instagram: myfabguy
Old 05-31-2014, 01:22 PM   #16
WCHLVR
WCHLVR's Avatar
Thanks Tiny! Putting it together for a good friend/customer. Solid work on that Z! I love that its an 8 Lug. Planning to keep it 8?
Old 05-31-2014, 04:59 PM   #17
tinydb84
tinydb84's Avatar
Yeah I am going to keep it 8 lug. Never going to tow anything but I am playing with the idea of a turbo LS (already have the LS) so I figure the 8 lug rearend couldn't hurt.
Back to the original poster. DV8 (a board member here) did his own version of a raised crossmember that he has shared the measurements on before. Shoot him a message if you are interesting, he is usually very helpful.
David
Instagram: myfabguy
Old 05-31-2014, 06:33 PM   #18
-praisethelowered-
On my '63 I sectioned my '73 crossmember 2" and re-bolted it 1" forward.
There was not room to move the steering box up 2" and forward 1"I - it would be in the middle of the core support bracket - So I figured out how to install a R&P unit and matched where the center link would have been at 2" up and 1" forward.
-praisethelowered- is offline   Reply With Quote
