Old 05-21-2014, 12:50 PM   #1
Roll'nSlo
Roll'nSlo's Avatar
Lowering springs too weak for a bbc???
I'm going to use 3" drop spindles but was thinking I may want to lower it a couple of more inches. What I'm worried about is the spring rate, will typical lowering springs carry a bbc??
Roll'nSlo is offline   Reply With Quote
Old 05-21-2014, 02:03 PM   #2
tinydb84
tinydb84's Avatar
Re: Lowering springs too weak for a bbc???
Drop springs typically have a higher spring rate and I would ASSume they would feel better in with a big block over a small block.
David
Instagram: myfabguy
Old 05-22-2014, 12:06 AM   #3
66 C10 383
Early Classic sells drop front coil springs in 1" & 2" in big block versions along with stock height springs. Small block versions also have a 1.5" drop version in addition to the other drops.
I'd give them a call and talk to them.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 05-22-2014, 08:08 AM   #4
Roll'nSlo
Roll'nSlo's Avatar
Thanks. I'll give them a call.
