05-21-2014, 04:12 PM | #1 |
Dropping the rear??
I'm thinking about dropping the back of my '66 about 5". My question is if I use 3" drop springs and 2" blocks do I have to notch the frame??
05-21-2014, 04:33 PM | #2 |
Re: Dropping the rear??
You should not need to. I have a 5 inch drop and it has never hit the frame. You will need to trim the bump stops. I think 6 inches is when you have to start worrying.
05-21-2014, 06:36 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Need an adjustable panhard bar (track bar) and you won't be able to tow or carry as much.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-21-2014, 06:50 PM | #4 |
Well, panhard bar will be my next prob. I'm looking for an affordable Ford 9" and will have to fab brackets for it. Weight will never be a prob. I'll never haul anything with this truck. Now I'm curious about launching.
05-21-2014, 09:02 PM | #5 |
We don't use the "F" word here............LOL
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
05-22-2014, 12:07 AM | #6 |
If you are running 15" wheels the 2" blocks will drop the bottom of the U bolts below the scrub line (bottom of the wheel). If I remember correctly the max you should use with 15" wheels is 1.5" blocks.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
05-22-2014, 08:11 AM | #7 |
I'm considering running 17" wheels. I may just use 1" blocks and 4" springs. I just don't want to notch my frame is the problem. It weakens it IMO.
05-22-2014, 08:39 AM | #8 |
67-72 parts collector,…
The rear drop springs are all the same price.
I would get your drop with the spring alone,... and then spend your "lowering block money" on drop shocks, an adjustable track bar, and rear shock relocators. These are all the standard parts for lowering the rear of a trailing arm truck.
05-22-2014, 10:58 AM | #9 |
Can i ask why people use the F___ 9" rear rather than a Chevy rear. I've never had a rear go bad on me. I"m just wondering what the advantages are? thanks for the info.
05-22-2014, 11:29 AM | #10 |
I'm planning on dropping a 600-700hp 496 in my '66. My stock rear end won't last anytime at all. I'm also looking for a Dana 60.
05-22-2014, 01:52 PM | #11 |
Never Ending Projects
CPP makes an adjustable track bar that is bent to clear a 9" rear end. It uses the stock frame mount and has a bracket for the right trailing arm. You don't have to mount anything to the axle itself. I bought one to clear the diff cover I was going to use. After I mocked everything up, I realized on my panel, it has the rear gas tank so you'll never see that cover from behind. Doh!
Here's a pic to show how it route past the housing.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-22-2014, 01:56 PM | #12 | |
05-22-2014, 01:59 PM | #13 | |
So if I'm understanding everyone correctly, I can lower the truck 5" without having to notch the frame. Right?? |
05-22-2014, 02:27 PM | #14 |
Correct, but don't go any more than 5", and don't put anything heavy in the bed. Get the adjustable track bar and relocate the shocks. Buy a good quality gas shock, too.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
05-23-2014, 08:06 AM | #15 |
Go bags in the rear! you can then tow if you want to, haul if you want to and the ride is better.
05-23-2014, 11:07 PM | #16 |
The C10 rear ends are weak if you are going to do any heavy towing, hauling or apply any serious power to them. The axel bearings ride directly on the axel shafts without an inner race so the axel shaft itself wears. I purchased a 28' travel trailer weighing in at 6,000lbs and since I plan on towing it with my 64 C10 I also plan on installing a Ford 9" rear end. There's quite a lot of 9" Ford rear ends to choose from that will fit our trucks. 67-72 Ford full size trucks, 60-64 full size cars, 71-73 Mustangs, 67-73 Torino, Ranchero & Fairlane are all 61.26" WMS to WMS. Our 60-72 C10's are 62" WMS to WMS. The absolute best swap is the 67-73 Torino, Ranchero & Fairlane rears because they use thick wall tubing & are 3.25" in diameter. And what do you know Pick-N-Pull is having a 1/2 sale this weekend, so you know where I'll be Saturday.
05-23-2014, 11:26 PM | #17 |
Thanks for the great info.
05-24-2014, 12:18 AM | #18 |
I know i should knw this BUT!
whats WMS? Thanks
The fleet 94 Chevy 4x4 reg cab 2018 Traverse (wifes car) 1977 SWB stepside 1949 Chevy truck |
05-24-2014, 12:37 AM | #19 |
05-24-2014, 09:28 AM | #20 | |
I know it's kind of off subject but, if I do 2" lowering springs in the front do I have to worry about the tire leaning? I cannot stand that. Also, will typical lowering springs carry the weight of a bbc? I have a local vendor I can get typical springs but they don't carry the bbc springs. |
05-24-2014, 10:04 PM | #21 |
Thanks!
05-25-2014, 11:23 AM | #22 | |||
CPP 5" rear springs and I still have 2" of travel. You will have to trim the bumpstops level with the frame. Quote:
05-26-2014, 12:41 AM | #23 |
From experience.... Just an FYI on front springs with a big block. The extra weight is good for about an extra 1" of drop from the advertised drop. i.e. a 2" spring will actually be about 3" drop. A 3" drop spring (4" total) will probably be resting on the bumpstops. Your best bet is a set of 2.5" spindles. That will not change from weight.
