Old 05-21-2014, 04:39 PM   #1
CATCHALLBLUE
CATCHALLBLUE's Avatar
Master cylinder bad?
I got a refurbished master cylinder from O'rielly's a week ago and began to bench bleed it today. I started to pump the MC got all the air out then i noticed the rear reservoir has a constant bubble popping out. It seems its not closing properly.
This master cylinder is faulty right?
CATCHALLBLUE is offline   Reply With Quote
Old 05-21-2014, 04:49 PM   #2
CATCHALLBLUE
Re: Master cylinder bad?
you can see the bubble forming on the right....
Old 05-21-2014, 05:53 PM   #3
chevy72blu
chevy72blu's Avatar
Even once you are sure you got all the air out, there is likely some more. Bleeding it also causes the big bubbles to break into tiny ones... those may take more time.
Let it sit for an hour or more before bleeding again. I usually do this a few times before bolting it up. Every time I'm surprised by how long they keep bubbling, but eventually they're gone. Double check your block off plugs as well - those little plastic turds dont always want to seal. Make sure to keep the reservoir full enough throughout the process. If the siphon tube gets any air in it, its time to start over.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-21-2014, 06:06 PM   #4
CATCHALLBLUE
thanks i realized i didnt bleed it enough finally the bubbles stopped.......
Old 05-21-2014, 06:11 PM   #5
CATCHALLBLUE
ok here is something wild...
I get the old master cylinder off and look what i find....
I pull a 3 inch cut bolt out...
ok what is going on here guys?
Old 05-21-2014, 07:55 PM   #6
davepl
davepl's Avatar
Someone lost the original plunger/rod and figured that'd be close enough. I guess if it drove it was. I had to make my own once but I used actual rod, not a bolt, and rounded the nose, and so on.
The original rod (at least in my 3/4t drum truck) looked roughly like that but it was smooth and had a "mushroomed" end on it. If you need photos let me know.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-21-2014, 08:04 PM   #7
CATCHALLBLUE
photos would be awesome!
Is this part readily available? Do i take the booster apart to assemble? Been searching the forum for any info on this but no luck so far....
Old 05-21-2014, 08:16 PM   #8
davepl
davepl's Avatar
Here you go! Looks like the rod tip is adjustable. Normally I'd make that adjustment at the pedal rod on the 72 but this is from a '70 3/4t.
Old 05-21-2014, 08:29 PM   #9
chevy72blu
chevy72blu's Avatar
Yep, someone definitely improvised a new booster rod
The pushrod is usually supplied with a new booster. I'm not sure of the part number to find one individually. See if a parts store has a booster and try to swing a deal. Otherwise, contact a board vendor
RIP EastSideLowLife
Old 05-21-2014, 10:01 PM   #10
CATCHALLBLUE
cool thanks!
Mines a '69 1 ton. Still looking for a replacement. Thinking about calling the chevy dealer tomorrow.
