2002 rearend
Anybody put a 2002 Silverado rear end in a 72 c10. From what I can gather there about 5 in wider. Sounds like to me might be to wide. I'm just looking for limited slip and disc brakes and I just so happen to have one laying around. Any thoughts
Re: 2002 rearend
I have a couple of these lying around and have had this same thought...they sure look wide.
Re: 2002 rearend
I no I hope somebody gives some info,
Re: 2002 rearend
i used the rear end from a 99. its a 14 bolt semi float. factory discs and a gov lock(i replaced it with a true trac) i dont have he measurements but it fit.
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
Re: 2002 rearend
So it must have not looked to wide. My problem is I'm doing my frame and drive train with no body and my step side is in pieces. I think I'm gonna try it and hope it don't look to wide.
I have a radical idea!
Re: 2002 rearend
The E-brake set-up is junk on them, if you are considering going with a straight shift. I broke the one in my 2000 Z71 when it was 3 months old, and the E-brake was crap after about a year and half of owning the truck. It was one of the many reasons I sold that truck.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Re: 2002 rearend
i think it will work cause the offset on the 2002 rear wheels would make up the diff
Re: 2002 rearend
2" diff in axle shafts 2002 is 33.57 72 is 31 5/16 long so not too much i think your ok
Re: 2002 rearend
I'm going to try it maybe this weekend ill work on it a bit. I wish I could lead some pics. But it won't let me. Or I just don't know what I'm doing.
