05-21-2014, 06:25 PM | #1 |
Can you identify my carb?
It's a holley 4 barrel but what model?
05-21-2014, 06:32 PM | #2 |
Re: Can you identify my carb?
Should be a sticker and/or cast numbers on the side of the main body. Mine shows 1850s, which is 600 cfm vac sec. Looks like that one sticker on the right shows the same.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
05-21-2014, 06:43 PM | #3 |
Can you tell me what's going on here? Isn't that a kickdown cable? I haven't drove the truck much since I got it. I'd have to go drive it to see if it kicks down or not.
05-21-2014, 08:16 PM | #4 |
That sticker fell apart when I touched it. I tried to look behind it and the numbers had been etched off. I think it says 1850s by looking at the picture.
05-21-2014, 08:46 PM | #5 |
4160, non adjustable floats, more than likely a 600 or smaller
"DON'T TOUCH THE TRIM!!"-Early Kyler |
05-21-2014, 08:52 PM | #6 |
How do you know?
05-21-2014, 09:59 PM | #7 |
05-21-2014, 10:36 PM | #8 |
Could be a kickdown, could be cruise control. Can't tell from the picture. If it is kickdown, on a th350 that controls line pressure as well as kickdown. Not good to leave it undone as clutches can slip with too little line pressure.
1850s is a 600 cfm just like mine.
05-22-2014, 03:25 PM | #9 |
Kickdown cable disconnected on a TH350 wont hurt it. It will just shift early. TV cable disconnected on a TH700 will destroy it in short order.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
05-22-2014, 05:33 PM | #10 |
