05-21-2014, 08:59 PM | #1 |
How hard is it to change ignition mechanism?
It's getting stuck in the crank position. Not good. I have to turn it backwards. It's in my 85 c10 tilt steering column.
Thx y'all. |
05-21-2014, 09:01 PM | #2 |
Another Day, Another Dollar
Re: How hard is it to change ignition mechanism?
There's a little hole underneath that you push in with a tiny screwdriver when it's in the run position and it pops right out. Easy peasy
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
05-21-2014, 11:05 PM | #3 |
might be the spring loaded switch at the bottom of the collumn
the key switch is just a remote control for the real switch at the bottom. |
05-22-2014, 07:52 AM | #4 |
Not quite, I think you're thinking of previous columns. I just did mine over the weekend, you have to remove the steering wheel, dust cover, lock ring and turn signal cam. There is a small bolt that holds the ignition lock in place.
05-22-2014, 11:16 AM | #5 |
Parts and more parts
Once again, figure out if it is the ignition lock part in the column or the sliding ignition switch assembly that is on top of the column under the dash. The ignition lock assembly is connected to the sliding switch with a rod that works off of a cammed sliding rotational piece that attaches to the locking assembly. If that switch needs to be changed out, it can be done without taking the column out of the truck, but you have to take the bolts out of the column and drop it down from the dash. It also helps if you take the instrument panel loose, too.
You will need a steering wheel puller and a torx screwdriver to take the small bolt out that holds the locking mechanism in the column.
Frank |
05-22-2014, 11:38 AM | #6 |
Your right, I was thinking of my old '03 f150
05-22-2014, 04:01 PM | #7 |
Did one two weeks ago after losing my keys. I watched a couple YouTube videos and headed for the garage. It's actually a pretty easy job just take your time. Hour and a half later it was done. You'll want a steering wheel puller and something to compress the internals to get the main nut off. I built my own tools but you can usually rent these two tools from your local auto store.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
