Old 05-21-2014, 11:37 PM   #1
TwoFiftyShifter
C10 to K10 rear end swap
Have a K10 with a blown rear. Neighbor has a parts truck C10. Can the rear be swapped to my truck, and I slide in my 6lug axles?
Figured it is worth a shot.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-22-2014, 08:44 AM   #2
Rubble
Re: C10 to K10 rear end swap
Should work ok,done this same swap on couple of my trucks a few years ago. The only thing I ran into,tried to use a heavy half rear 2wd for my 80K10. That didn't work though,if I remember correct the heavy half axles are a bit bigger diameter.Normal 2wd worked fine.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 05-23-2014, 12:02 PM   #3
TwoFiftyShifter
Glad to hear you have done the swap. I may need to do this.
1982 K10 SWB
Old 05-23-2014, 08:36 PM   #4
Rubble
Ya,just a matter of swapping axles for the correct bolt pattern.When I did this on my '80 K10 I was lazy & just ran the five bolt pattern from the heavy half for a while.Only drawback was I needed to pack two different spare tires.
