05-22-2014, 11:43 AM | #1 |
Broken Cross Pin Bolt
So I broke the cross pin bolt when I was removing the rear axles. I know this happens a lot. I found a replacement bolt on Rockauto for $1.38. No complaints there but they want to charge me $9 to ship it.
Also they have 3 different cross pins. USA STANDARD GEAR Part # USA33067 Cross Pin Bolt One of our most popular parts Rear; RWD; GM 12 Bolt Truck $1.38 USA STANDARD GEAR Part # USA33068 standard Open cross pin bolt Rear; RWD; GM 12 Bolt Truck Rear; RWD; GM 1/2 Ton truck $2.23 USA STANDARD GEAR Part # USA33344 Positraction (Limited Slip) Cross Pin Bolt Rear; RWD; GM 12 Bolt Truck Obviously its not positraction for mine but what is the difference between the first two as the picture looks the same. I plan to order the first one. Any help is appreciated
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
05-22-2014, 12:13 PM | #2 |
Re: Broken Cross Pin Bolt
did you get the broken piece out of the carrier? order both pins--------
1961 chevy K10 my build is------------61K10 build |
05-22-2014, 12:14 PM | #3 |
Yes I did. That's not a bad idea.
05-22-2014, 12:39 PM | #4 |
Aailable at some parts stores under the HELP brand, #81048 for non-posi
05-22-2014, 01:31 PM | #5 |
Your local GM parts dept can get those. If it's a larger dealership, they might even have them in stock.
05-22-2014, 01:51 PM | #6 |
Awesome thanks for the help guys.
