Old 05-22-2014, 02:19 PM   #1
Shox Dr
Water ingress
Where/how does the water get into the cab, that ends up in the rear corners
Cheers
Shox Dr is offline   Reply With Quote
Old 05-22-2014, 03:08 PM   #2
59chev
59chev's Avatar
Re: Water ingress
If the seam sealer has dried up on your drip rails the water can seep in and run down the inside of the back wall of your cab. It then collects in the rear cab corners.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 05-22-2014, 05:44 PM   #3
OrrieG
OrrieG's Avatar
Re: Water ingress
The inside of the back corners are open to the inside and outside corners below. There are holes where the inner and outer join that get clogged. When Farmer John, and guys like me who used the truck, hose down the inside to get rid of the mud, spilled gas, dog hair, etc, water runs down and gets trapped between the inner and outer panels. As the inner panels rust away water off the tires, pavements, etc. splashed up and get trapped too. I made panels to close off that area on mine and made sure my new inner (I fabricated) panels had generous drainage space. 59chevy is right about his too, I had never thought of the drip rails leaking. Also if you live in an area that has high humidity condensation can form on the inside of the cab corner and run down too.
OrrieG is offline   Reply With Quote
Old 05-22-2014, 07:01 PM   #4
BlueJeep
BlueJeep's Avatar
Re: Water ingress
If it's an AD truck the seam in the back of the cab between the top and the bottom half often leaks water, so every time you wash the truck it will leak.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
