Old 05-22-2014, 03:45 PM   #1
BigSix
Do I have the wrong gas cap?
Just went to take my gas cap off after replacing it recently. First time I have taken it off and there was a good amount of vacuum. I am thinking that maybe I got a non-vented cap by accident? Are we supposed to run vented caps on our trucks? BTW I have the in-cab tank with a V6 and Holley.
BigSix is offline   Reply With Quote
Old 05-22-2014, 03:56 PM   #2
imjeff
imjeff's Avatar
Re: Do I have the wrong gas cap?
Should be vented...sounds like it's not.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 05-22-2014, 03:57 PM   #3
BigSix
I'm guessing if there is vacuum on the tank that means not vented cap? Would vented mean there is a one way valve to let air into the tank but not let gas/fumes into the atmosphere?
Old 05-22-2014, 04:19 PM   #4
grs
Gas fumes will go into the atmosphere. You will be able to smell gas around the gas cap on a vented gas cap.
grs is offline   Reply With Quote
Old 05-22-2014, 09:46 PM   #5
firemanjimtfd
firemanjimtfd's Avatar
Last 2 I bought at parts store and truck supplier ended up not vented . I took small plastic cap on bottom side of cap and took out spring and rubber check valve. Put small cap back on works now. Cheap fix.
firemanjimtfd is offline   Reply With Quote
Old 05-23-2014, 10:26 AM   #6
BigSix
If a vented cap is gonna make me smell gas around the cap then I'll leave the non-vented and just crack it from time to time. Doesn't seem to be much of an issue and I am sure I'll eventually do an engine swap with return line.
Old 05-23-2014, 01:20 PM   #7
imjeff
imjeff's Avatar
Without a vented cap you may eventually collapse a line or the tank. At a minimum it can cause fuel supply issues. The vent is mainly to allow air in to replace the fuel going out.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 05-24-2014, 12:44 AM   #8
DakotaKid
on a hot day it will also cause vapor lock, fuel will boil a a lower temp n a vacuum.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 05-24-2014, 02:16 AM   #9
franken
Hold it right there...
1965 GMC 4WD 3/4 Ton Fleet V6 SM420 D44/60
I request lots of pics of this truck.
franken is online now   Reply With Quote
