05-23-2014, 01:51 PM | #1 |
Junior Member
Using Panel Bond Adhesive on a 67-72
I was thinking of using it to replace my outer rockers and possibly some other patch pieces I will have to do. We use it regularly on the newer trucks here at the body shop I work at for collision repair and I really like the product.
I'm just wondering who has used it on a 67-72, what you used it on, and what you thought about it? |
05-23-2014, 03:05 PM | #2 |
Re: Using Panel Bond Adhesive on a 67-72
I used it on my '87. I replaced cab corners and one spot behind the rear wheel. You can read all about it in my build thread, starting on page 4:
http://67-72chevytrucks.com/vboard/s...d.php?t=342926 It's been five years and it still looks new, with one exception: the LH cab corner was in close clearance to the gas tank shield and (apparently) the two would hit when the frame would twist (like hitting a driveway at an angle). That was enough to cause a small crack in that area. I ended up taking off the gas tank shield to alleviate that condition. Other than that I'm pretty happy with it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-23-2014, 03:16 PM | #3 |
excellent stuff , used it to put both quarters on my 64 chevelle , has held up well
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
