05-23-2014, 08:01 PM | #1 |
help with rear drop blocks... need pics of ece pan bar with blocks
I have an ECE drop kit. Have the adj panhard bar. Wondering do I put my lowering blocks under it or on top of it on the pass side?? Any pics would be appreciated...
05-24-2014, 07:30 AM | #2 |
Re: help with rear drop blocks... need pics of ece pan bar with blocks
I'm not gonna say this is right or wrong but its how mine went together.
if i would've put the mount under the block i would've had too notch the corner off the block.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-24-2014, 10:40 AM | #3 |
I paid a guy to do mine. That's how he did it. Talked to 2 guys at ECE. Mark said top or bottom was fine. Stan ? said it should be on top of bar bracket. I'm confused.
05-24-2014, 11:35 AM | #4 |
67-72 parts collector,…
In my opinion,... the lowering blocks purpose is to just move the rearend up.
I install the ECE trailing arm bracket directly on top of the trailing arm,... then put the block on top of it.
