Old 08-01-2003, 10:27 AM   #1
72gmcshorty
72gmcshorty's Avatar
Rad fan shroud question?
When using electric fan setup, do I need a shrouded fan? Will a non shrouded fan cool a 4 core rad well enough?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 08-01-2003, 10:41 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Probably not. Need more info such as size of fan, cfm, cooling problems when had mechanical fan?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-01-2003, 10:51 AM   #3
landon4421
Life is Good !
landon4421's Avatar
I would say yes you need a fan schroud. The air needs to be pulled through the radiator evenly to cool correctly. Here is a post for another board about the fan schroud thing. Hope this helps, follow the link below. It will give you an idea of what you need. Good luck, Landon
http://www.myoldtruck.com/forums/sho...=&threadid=253
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 08-01-2003, 11:03 AM   #4
72gmcshorty
Any idea what kind of fans he used in that link?
1992 Gmc 2wd
Old 08-01-2003, 11:29 AM   #5
Figment412
Won't that limit the airflow throught the radiator when running at higher speeds like down the highway?
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 08-01-2003, 11:34 AM   #6
landon4421
Life is Good !
landon4421's Avatar
72gmcshorty, I have no idea but I can find out and someone or me will let you know.
Figment412, no I don't think it will make much differance. But then again I wont know for a few years, my truck is not done yet. I heard that the more even the flow of air to the radiator the better the cooling? but like I said I have no idea.
Old 08-01-2003, 12:35 PM   #7
70c10
67-72 Addict!
70c10's Avatar
I hear 93-97 Nissan Ultima fans are almost a direct fit and work good.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-01-2003, 03:51 PM   #8
Jwill41
Jwill41's Avatar
I had a Nissan fan in mine until one of the motors started making noise. I think it was an early 90's Altima. It was dual fans and it fit perfectly. Now I have a Hayden 16" mounted in the shroud where the original fan would be. Works great.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-02-2003, 12:25 AM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
www.vintageair.com
They have a nice PDF catalog, page 70 of which has several fans and shrouds displayed. It seems like another A/C company makes an electric fan/shroud combo that is designed to fit our trucks, but I have not found it, yet.
Member Nr. 2770
