1972 blazer rear seat seat belts
Did the rear seat have two or three sets of seat belts
Re: 1972 blazer rear seat seat belts
Three. Not the best pic but you get the idea.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
I believe either or.....wasnt 3rd set an option? Seems that some of my rear seats only had two sets.
I never thought of it that way. If I recall correctly, I read somewhere that basically everything after the drivers seat was an option on these. But I could be wrong.
SKINNY TIRES RULE!
I've never seen the third set of rear seat belts listed as an option, but it doesn't mean that isn't the case. Of the three Blazers I've owned, all three had 3 seatbelts in the rear (one non-ac CST, one low option and one non-cst AC).
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I don't mean to hi jack your post but my 72 Blazer has three sets of seat belts on the rear bench seat. What I am wondering is that I only have two rear supports on the seat. There isn't any mounting holes in the bottom of the original seat cover. I am guessing that the center seat belts bolt directly to the floor?
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
On my blazer there are four rear stands. The seats belts bolt to the two middle stands. I can take a pic when I get home.
Upon closer inspection of your pic, your two stands are actually the middle ones and you need to get two more for the outside. They won't have nuts welded on them.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 Last edited by YBNORML; 05-26-2014 at 10:12 AM. Reason: More info |
Asolde, i have one or two rear seats that only have the outside stands too and theyre original, never been out of the truck, they must bolt to the center two floor holes
Here's a pic of mine. This is how it was delivered. As far as I can tell the first time the seat was removed was for the carpet install. They must've done the rear seats lets a few different ways. Kinda weird though.
thanks guys for all of the info. I also have two bench seats that I have bought for my blazer and one has two rear brackets and the other has four. If anyone has anymore info on this I would like to hear from you. Thanks
SKINNY TIRES RULE!
Here is a close up of mine. Outer belts bolt to the nuts welded to the supports, inner belts bolt directly to the floor. you can see that the center has two belts (one laying on the floor and one feeding through the seat.)
Interesting. My outer belts bolt directly to the seat itself, through the side.
