05-24-2014, 10:08 AM | #1 |
Is a spare tire 1/2 smaller diameter okay?
I've used a spare probably 3 times in my life, 2 of which were a result of my wife jumping a curb Anyway, is there an issue with using a spare that is 1/2 inch or so shorter?
I could use the same size as is on the truck, but it would be nice to have it a little more narrow since I'm gonna keep it under the bed. Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
05-24-2014, 10:10 AM | #2 | |
Re: Is a spare tire 1/2 smaller diameter okay?
Sam |
05-24-2014, 11:43 AM | #3 |
Just be sure to use it in the front only if you have a posi or a locker in the rear.
05-24-2014, 12:25 PM | #4 |
As stated above, don't use if you have a posi or locker, with a regular diff your ok for short hop until you get the other tire fixed.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-24-2014, 04:14 PM | #5 |
Thanks guys! I figured it would be ok, but I wanted to check and make sure. I'd keep the 15" spare under there, but it won't clear discs and it's approx 2 1/2" smaller in diameter than the new 16's.
05-25-2014, 07:57 AM | #6 | |
1970 C10 Short Stepper with 71/72 front clip. |
05-25-2014, 09:24 AM | #7 |
I'm talking about the original 6 lug 15" drum only wheels that were used up to '70.
