Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-24-2014, 09:49 PM   #1
60n60Apache
WTB 60-61 Chevy, front 6 lug hub.
WTB 60-61 front 6 lug hub.
I'm looking for a front hub for a 1960 Chevy Apache.
60n60Apache is offline   Reply With Quote
Old 05-25-2014, 09:30 AM   #2
davbowen
davbowen's Avatar
Re: WTB 60-61 Chevy, front 6 lug hub.
I've got both front hubs off a 63. don't know if they are the same. they are complete spindle to drum.
davbowen is offline   Reply With Quote
Old 05-25-2014, 09:36 AM   #3
LT1 Burb
LT1 Burb's Avatar
I have a few also.
LT1 Burb is offline   Reply With Quote
Old 05-25-2014, 03:27 PM   #4
60n60Apache
Don't know if the 63 hub will fit.
The hub: center need to be 3" , 6x5.5
I only need one. How much shipped to 30349?
Send me a pm.
Old 05-25-2014, 04:06 PM   #5
davbowen
davbowen's Avatar
hub diameter measures 3 9/16. let me know if you're still interested.
Old 05-25-2014, 04:21 PM   #6
Old Truck Man
Old Truck Man's Avatar
If you have a torsionbar frontend only hubs drums & bearings from a 61 &62 torsion bar frontend will fit. 63 parts wont work.
Old Truck Man is offline   Reply With Quote
Old 05-25-2014, 04:56 PM   #7
60n60Apache
Yeah, my hub is attached to the drum.
Old 05-26-2014, 04:12 PM   #8
Bregion
I have some off a 62. What all are you wanting?
Bregion is offline   Reply With Quote
Old 05-27-2014, 12:22 AM   #9
60n60Apache
Bregion,
I need the hub with the drum attached.
Old 05-27-2014, 10:19 AM   #10
Bregion
This work for ya?
Old 05-27-2014, 05:32 PM   #11
60n60Apache
What the other side look like?
Old 05-27-2014, 08:19 PM   #12
Bregion
Other side. Ill check on shipping. I bet its gonna cost alot with neing so heavy.
Old 05-27-2014, 09:49 PM   #13
60n60Apache
Hey Bregion,
To reduce the weight remove the pin,nut,up to and including the bearing and hub. don't need the rest, brake shoes etc...
Old 05-27-2014, 09:56 PM   #14
Old Truck Man
You can grind off the rivets that hold the brake drum to the center hub. that will allow you to separate the drum from the hub. the center hub will then ship in a us post office flat rate box.
Old 05-27-2014, 10:18 PM   #15
60n60Apache
yes, but I need both the center hub and the drum together.
Old 05-28-2014, 08:58 AM   #16
paulspickupparts
If you need the drum also make sure you have enough meat in the drum to have turned. Nothing worse than buying a drum that is out of spec and you cannot have it turned. Then you get to buy a second drum. If your hub is good you can buy a new drum, grind your rivets out , install the new drum and good to go.
paulspickupparts is offline   Reply With Quote
Old 05-28-2014, 11:21 AM   #17
60n60Apache
Paul,
Will I have to rivet the new drum to the hub?
Old 05-28-2014, 11:45 AM   #18
paulspickupparts
It is a good idea to re attach to your hub somehow whether by rivets or other means . Your wheel studs also work as attaching devices but rivets or bolts never hurt. Ask a good brake shop. Do not read it on the internet.
Old 05-28-2014, 11:55 AM   #19
paulspickupparts
I did a quick check and found a new drum for $42 plus ship. I would buy from one of the vendors that support this site. Used is ok also as long as you have margin to turn safely. I only sell used parts but everyone selling new and for the price I cannot compete.
Old 05-28-2014, 12:26 PM   #20
Bregion
Heres a pic of the other hub taken off tye other side. Dirty but not worn ti bad frim what i can tell.
Old 05-28-2014, 01:20 PM   #21
Old Truck Man
Originally Posted by 60n60Apache View Post
Paul,
Ive ground them off and never bothered to reattach them and never had any problems. The wheel and 6lug nuts clamp it tightly. on many vehicles the brake drums are not attached to the drums. having them where they can be removed without disturbing the wheel bearings is handy.
Old 05-28-2014, 05:04 PM   #22
60n60Apache
The previous only had changed the hub and when reattached the rivets was left large. I'm putting on after market wheel that need adapters and rivets are not letting it go on flush. So I can grind rivets down flush and have no problem.
I will try it tomorrow. will let you know how it works.
Old 05-30-2014, 07:34 PM   #23
60n60Apache
I grind down the rivets and everything looks like the other side.
Thanks alot.
