05-24-2014, 11:48 PM | #1 |
Sanding down my frame and found this
Does any one know what this is for or means? My door vin and paperwork says 67 c10. It was a one owner and he said the frame has never been replaced.
Thanks |
05-25-2014, 12:12 AM | #2 |
Re: Sanding down my frame and found this
Guess I should include a pic |
05-25-2014, 12:49 AM | #3 |
Well that surely makes you go ummmm. Can you find any other numbers on your frame? I thought that vin numbers should be the same on the frame as the vehicle.
1970 C20 Camper Special SBC350 / TH350 '84 C20 Front Disc Brakes/Control Arms |
05-25-2014, 12:55 AM | #4 |
Those are the only numbers I have found
05-25-2014, 01:05 AM | #5 |
Look on the left top side of the frame rail up close to your power steering box.This area should have part of your vin number stamped into the top of the frame rail in this location...
Kev's-C-10 |
05-25-2014, 03:38 AM | #6 |
No these are the only numbers on the frame I can find
05-25-2014, 03:57 AM | #7 |
I dont know brother, maybe its not even a date. Instead its a code for the factory. I can't place the location of your numbers... Where are they? I will look on my frame to see if I can see anything. (Tomorrow)
Something I did find is that 73 and up frames are thicker metal so if you can find a older frame and mic it against yours that might tell you if its a newer or older frame.
1970 C20 Camper Special SBC350 / TH350 '84 C20 Front Disc Brakes/Control Arms Last edited by Zable49; 05-25-2014 at 04:09 AM. |
05-25-2014, 09:52 AM | #8 |
Are you coil or leaf spring rear end? Sounds irrelevant but I've never seen a 67 c10 without coils and a 78 would be leaf
05-25-2014, 09:59 AM | #9 | |
The Older Generation
Leaf springs were optional on '67 C-10's.... LockDoc
05-25-2014, 10:35 AM | #10 |
Here are pictures I found on my 69 frame in addition to the partial VIN in the normal 2 locations. I assumed they were numbers to I.D. parts for frame assembly. It doesn't look to me like any of the numbers are date related. My truck is a C20 produced in Dec., 1968. As I recall these were on the right and left frame rails near the front crossmember.
05-25-2014, 11:02 AM | #11 |
These are located on the frame where the drivers door would be. My truck is also leaf spring I just converted to coil PITA
05-25-2014, 11:05 AM | #12 |
Don't know what those numbers mean, but they were put in at the time of production, of the frame rail. You want the numbers that were put in at the time of production, of the truck. This number is a partial vin (last 8 digits of your VIN) and will be stamped on the top of the driver side frame rail, in two places. See pic.
05-25-2014, 12:12 PM | #13 |
How about a picture of the whole frame ..
05-25-2014, 12:17 PM | #14 | |
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
05-25-2014, 01:34 PM | #15 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
05-25-2014, 01:50 PM | #16 |
I just rechecked my frame pictured in post 10. That's where mine are stamped also. About 6" behind the front cab mounts. The standalone 452 is where the right front bumper bracket attaches. The number shown in the third picture is actually 3935812. The 1 did not show up well in the picture. If it helps, I am 100% sure my frame is original to my 69 coil spring 3/4 ton. Does anyone know who made the frames for GM? As I recall, A.O. Smith made frames for some companies.
