05-25-2014, 12:32 AM | #1 |
Jerking while at cruise speed
No matter what gear I am in the truck wont stay at a constant cruise just jerks like I am goosing the throttle. Any ideas as to what may be causing this?
As always thanks everyone for the feedback. Not sure of exact tranny but has granny 4 speed in it. |
05-25-2014, 08:29 AM | #2 |
Re: Jerking while at cruise speed
Oh, you mean the TRUCK is jerking........
05-25-2014, 08:34 AM | #3 | |
By the way, your thread title should win you a POTD award. (post of the day) Good luck...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
05-25-2014, 10:50 AM | #4 |
05-25-2014, 10:59 AM | #5 |
It may be too lean at low load.
What it your air fuel ratio? My 350 won't do a light cruise much leaner than 15:1. Any leaner and it jerks. Maybe you have a small vac leak or the floats are too low?
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
05-25-2014, 05:41 PM | #6 |
meowMEOWmeowMEOW
Didn't California pass a law against on-road jerking? ..... as well as Assisted On Road Jerking?
05-25-2014, 10:51 PM | #7 |
Chevy addict
Possible water in the gas
05-26-2014, 10:38 AM | #8 |
Some engines will run rough at part throttle because of excessive timing. Try driving with the vacuum advance disconnected. If it helps you may have to get an adjustable vacuum chamber & limit the advance.
05-26-2014, 10:49 AM | #9 |
Check the fuel filter also. or just replace it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
