Old 05-25-2014, 12:55 AM   #1
terbronco7
terbronco7's Avatar
Pics of 348/409 powered trucks
Leaning towards purchase of good used 348 and would like to know how difficult it would be to swap out my very tired 230, anything special needed to be done to get it to fit etc?
terbronco7 is offline   Reply With Quote
Old 05-25-2014, 08:06 PM   #2
SSpeed66
SSpeed66's Avatar
Re: Pics of 348/409 powered trucks
It will bolt in no problem... it's a !!!
Living The Canadian Dream in British Columbia
SSpeed66 is offline   Reply With Quote
Old 05-27-2014, 09:25 AM   #3
1963c-10
1963c-10's Avatar
Make sure to have a healthy amount of money for the 348 parts as I'm finding. Most parts are more expensive than the big block parts I'm finding, but it will fit in no problem.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-28-2014, 06:26 PM   #4
64chevycrewcab
I have a 348 that i plan to put in my 64 crew cab. have not started the install yet. Debating on changing it to a tri-power.
1961 Apache 10 with side trim
1964 4 door crew cab C20
1966 Chevy Suburban with custom trim
1961 K30 with a 4-53T Detroit diesel
1966 GMC 4X4 Suburban
64chevycrewcab is offline   Reply With Quote
Old 05-28-2014, 06:47 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
You might find these threads of interest:
http://67-72chevytrucks.com/vboard/s...&highlight=348
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-30-2014, 02:44 PM   #6
1963c-10
1963c-10's Avatar
Found this 62 on NC CL and it has a 348
Old 05-30-2014, 05:02 PM   #7
SSpeed66
SSpeed66's Avatar
348's have the dipstick on the other side, 409's this side
Old 05-30-2014, 07:01 PM   #8
Slow Build
Slow Build's Avatar
For those with a no limit budget.
http://www.ultrastreet.net/engines/509_classic.php
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-02-2014, 09:17 AM   #9
1963c-10
1963c-10's Avatar
Didn't even catch that in the pic, but you are correct. I got the 348 up off the ground and installed in the fleetside for the time being. It will let me mock up what I need to, but will have to come back out after the step side is done for rebuild.
This is set in the rear holes, but due to very tight clearance issues on the pass side, I will more than likely move it to the forward holes for final install. I will also go to the CPP tubular mounts as the factory 63 perches do not like the cast iron manifolds. They will work, but would require some very minor trimming to make them work. I plan to run headers anyways, so I'll be going to the CPP mounts.
Old 06-02-2014, 09:46 AM   #10
MikeN
MikeN's Avatar
If I ever found a rebuildable core for a sane price, I'd love to do a 348 in my 64 C10. Awesome old school hotrod engine.
MikeN is offline   Reply With Quote
Old 06-02-2014, 09:48 AM   #11
1963c-10
1963c-10's Avatar
I'll keep my eyes peeled for you. I'm always looking for 348/409 parts.
Old 06-02-2014, 10:12 AM   #12
1963c-10
1963c-10's Avatar
A few more pics of the firewall clearance. The rear position could be used with a little massage on the pass side, but the engine will slide forward for my build. Plenty of clearance on the dist cap....even for a large HEI cap.
Guys running automatics....are you using the forward or rear mounting positions on the frame for clearance? Will the engine in the rear position leave enough clearance for the Powerglide?
Old 06-03-2014, 11:36 AM   #13
1963c-10
1963c-10's Avatar
Couple of pics a 348-409 forum member sent me for some inspiration.....what a great clean looking truck. Thought I'd share the pics...
Exact look I want, minus aluminum intake and headers.
Old 06-03-2014, 11:40 AM   #14
MikeN
MikeN's Avatar
Thanks! PM me if you find anything, for sure.
Old 06-03-2014, 11:50 AM   #15
1963c-10
1963c-10's Avatar
Talked with the guru's on the 348/409 forum about this truck. They agree its a 348 engine in the truck. Seems that a lot of the truck 348's used the same 6qt oil pan as the 409's with the dipstick on the passenger side.
Old 06-03-2014, 11:51 AM   #16
1963c-10
1963c-10's Avatar
Was one running in Ashville NC a week or so ago for like $800....I'll see if I can find the link. - No luck on that one.
But heres one in Danville VA, just over the border. Ad says it runs good.... link: http://danville.craigslist.org/pts/4472065623.html
Old 06-03-2014, 11:52 AM   #17
1963c-10
1963c-10's Avatar
Another 66 with a 348 from the 348-409 forum....great looking truck
Old 06-15-2014, 01:25 AM   #18
Captainfab
60-66 Nut
This one isn't in a truck, but I thought it would be of some inspiration for you 'W' engine guys.
Old 06-15-2014, 02:27 AM   #19
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Had a 348 In my 1960 Impala Best Motor I ever Had, Thinking About a 348 For my 1966 GMC
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 06-16-2014, 11:27 AM   #20
1963c-10
1963c-10's Avatar
Got the engine set forward and on the new CPP mounts Sunday. Cleaned up all my fitment issues minus the exhaust which I'm still working on.
Old 06-16-2014, 12:53 PM   #21
61K10
61K10's Avatar
not to tell you what to do with your build, just a suggestion. why not move it forward just enough to have clearance at the rear. the 348's are heavy and you are moving the eng forward by quite a bit. tks are already nose heavy. don't know if you could move the mounts just a little forward. however you do it, it will be a great addition to your f/s.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-16-2014, 01:30 PM   #22
1963c-10
1963c-10's Avatar
I have considered that also.....but I see a lot of guys who run the 4th gen big blocks in the forward position. To use the cpp mounts anywhere but in the forward locations, there would have to be a new lower hole drilled in the crossmember, which isn't a big issue. I think until I get the trans mated to it, I'll leave it here for now. Once the trans is on, if there is a bunch of extra room, I'll move it back 1". Which will still give me room on the valve covers and dist. cap.
Old 06-17-2014, 08:31 AM   #23
1963c-10
1963c-10's Avatar
Went outside with the old measuring tape again last night. I have 1 1/2" total clearance between the pass side valve cover (which is just a hair closer to the fire wall due to the firewall design). I could go back 3/4" comfortably, but I'm not sure that 3/4" is worth the time to set it back. I'd like to get the transmission mocked in 1st and see how the clearance looks on the firewall then before I make any moves on the engine.
Old 06-17-2014, 12:29 PM   #24
61K10
61K10's Avatar
so is the PG trans cast iron or alum? in your pics it looked like the early iron one. I would up grade to the later one or just go th350. here i am again telling you how to do things, don't mean to as you know what you are doing. If you use the early trans there is a ck valve that goes in one of the trans lines. this is not stock. don't remember all the details, but keeps the trans from leaking. converter bleed back. do a search on the net, should be info out there.
1961 chevy K10
Old 06-17-2014, 03:19 PM   #25
1963c-10
1963c-10's Avatar
The one I have is the original 58 cast iron powerglide beast that weighs around 250lbs. I will be going to a newer aluminum version when I find a decent one around here that's not all beat to hell. Guy called me yesterday with a 67 impala that he just removed one from, but he wants $400 and unsure of condition inside. I'm in no rush, so I'll keep looking.
I'm about 75% set on a powerglide, but if it was anything else....I'd probably go with a th400. I know these are not the popular choices, but they are what I want. And thanks for your input and ideas......no offense taken at all and I'm ok with criticism also.
