62 LS swap questions
So far everything has gone smoothly. Harness is wired and fuel system is in place. Im at the point to wire the starter.
The LS starter has one large post Bat + and I believe the S terminal. My question is do I run the existing purple wire from the stock 62 wiring system to small S terminal or is something else required?? I searched the forum and read a couple threads close to what Im looking for but nothing exact. Thanks Dave- |
Re: 62 LS swap questions
Looks like I should run the existing purple wire to the control side of a bosch relay and send battery voltage (fused) to the smaller post.
anyone ever heard of doing this for the LS swap? |
it's a 3 day weekend... check back in Tuesday.
![]() -W |
lol right,
and a few others
I moved this for you to the LS section.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
![]() Join Date: Sep 2005
I used the stock signal wire on my 71 to the s post
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
On this site I have always heard " it's not happening unless pics are posted"
I think you are on the correct path with the starter wire.
![]() Join Date: Apr 2005
Factory purple wire to S terminal, battery cable to the big terminal. You can also use the factory purple wire to trigger a relay that applies battery power to the S terminal if you choose. I believe that's the way most new cars are wired. Either way will work.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks you guys are awesome! Anyone happen to know what length belt to use if I'm just running the alternator ?
#13 | |
![]() Join Date: Mar 2011
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#14 |
Perfect thx
#15 |
And this is why I love this site, everyone is willing to help and as of now I have not seen ego's which is nice so no one is talked down on, and the expertise of the guys are top notch, heck all you have to do is look at the work that is knocked out, and posting the work and the steps along with pictures will help keep our hobby alive even when we are not !
I will be following this build and being in AZ. I may run into you.
1964 1 Ton flatbed service truck (sold) 1964 C-10 panel (project complete frame up build) 1957 210 post pearl orange |
#16 |
Stock purple wire to small Ls starter post worked perfect. The lm7 started first attempt thanks everyone for all your help!!
