![]() Join Date: Apr 2014
Soda blasting
Hi Guys
Have any of you used soda blasting for paint removal. My 69 has 4 paint colors on it and needs to be stripped. I have done the chemical removal many times and its messy. Same with sand blasting, taking a chance streching the metal and of course sand everywhere. I watched soda blasting on Youtube and some of them use a water stream to control dust, makes me worry about bare metal getting wet. Mike |
The Older Generation
Re: Soda blasting
There are a lot of threads on here about it. Here is one http://67-72chevytrucks.com/vboard/s...d.php?t=563199 Be sure and read the whole thread because there are some pros & cons, and some alternatives. I would say check with your painter about the different methods and see what he says. If you type "soda blast" into the Google search box at the top of this page, click on the circle in front of "67-72chevytrucks.com" and click on the "Google" button you will find most of the threads about it.... LockDoc
Re: Soda blasting
Maybe not practical for a whole vehicle, but have a look at Norton blue rapdstrip disks. There are cheap versions, but these last better.
![]() Join Date: Dec 2012
Re: Soda blasting
May be a stupid Question, but can you use a pressure washer for it?
1971 GMC Sierra 1959 GMC 100 |
Re: Soda blasting
Soda blasting leaves a residue on the metal that prevents the metal from rusting. I know it sounds strange. But there is a chemical reaction that cause it to make a sealant residue. You do need to wash with soap and water after if you want to paint it.
![]() Join Date: Dec 2011
Re: Soda blasting
A painter I know told me that the Soda Blast was a nuisance. He said the residue wasnt easy to fully remove and it gave him painting problems.
Dont know personally as I havent tried it- I have always done it manually. S
Love my wife, daughter, dog and truck. The more money you make the less happiness you have. My Build: The Little Tiger http://67-72chevytrucks.com/vboard/s...d.php?t=630564 |
Re: Soda blasting
My painter insisted on soda blasting. I had all the sheet metal, inside and out, and the frame done. Of course it had 2 resprays of the original color plus 4 macco type repaints of various dark greens. Came out like a brand new shiny nickel.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Re: Soda blasting
I use a local media blasting business that uses walnut shells to remove paint. He says that the walnut shells do an amazing job with rusty metal with less residue left behind. He has blasted a bunch of our stuff and everything came out super nice.
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
