Old 05-26-2014, 01:08 AM   #1
MuppetMan
MuppetMan's Avatar
Converting 4x4 to 2wd with c10 donor truck
I have read a lot of threads and articles on converting but all old articles. I'm considering converting my blazer to 2 wheel. Can buy a donor truck with all the trailing arms, front suspension etc...
With more and more people doing it and more available after market parts anyone have any feedback on this using a 2wd truck for parts?
Any feedback would be great
MuppetMan is offline   Reply With Quote
Old 05-26-2014, 06:35 PM   #2
smbrouss70
smbrouss70's Avatar
Re: Converting 4x4 to 2wd with c10 donor truck
I was about to set off on doing the same thing on a 4x4 Blazer before I found an original 2wd. I bought a short 2wd truck frame that I was going to cut 11" out of it between the trailing arm cross member and the transmission cross member. Then just transfer the body mount brackets off of another 4x4 Blazer frame that I have. Doing it this way would make it easier for normal truck lowering components to work properly, plus if anybody looked under the rear end they would see the frame rails kicked out and be fooled into thinking it was all original.
You can swap all of the 2wd parts onto an existing 4x4 frame if you are not planning on pulling the body off. Just mock everything up and take good measurements before you start drilling into the frame. You will have to make some brackets to hold the top of the coil spring or airbag though.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-28-2014, 04:13 AM   #3
BlazinC5
BlazinC5's Avatar
I did the donor truck thing with my Blazer. You can look over my build thread to get an idea of what it takes. Link in my signature.
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
