Old 05-26-2014, 02:45 AM   #1
mcrotty
What front clip do I have?
Hey fellas. New to the site and I've got a question about the front clip on my 1972 2wd C10 short bed. It has front drums on it with 6 lug. I thought all 1972 had disc brakes. Does not look like the suspension clip had been swapped before. I'm wanting to get some drop spindles but want to be sure I get the right ones. How do I check this out?
Mike
mcrotty is offline   Reply With Quote
Old 05-26-2014, 02:56 AM   #2
thelonerife
thelonerife's Avatar
Re: What front clip do I have?
Welcome to the site!
72s came with disc brakes. Its possible that the grille and bumper was changed to a 72 and your truck is a 69 or 70. I would check your vin# first. It'll tell you what year it is there. Your frame # will also tell you if the frame matches the cab. The frame # is on the drivers side engine compartment. on top of the frame rail. Is the rear a 6 lug also? If you have 6 lug spindles then you'll have to order drop spindles for a 70. The ball joints and tie rods holes are smaller on 70 and below.
thelonerife is offline   Reply With Quote
Old 05-26-2014, 02:58 AM   #3
thelonerife
heres a page from the lmc catalog to help you check the vin.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=9
Old 05-26-2014, 03:21 AM   #4
mcrotty
Yep, the rear is 6 lug also. The vin matches the title and frame stamping numbers. Its a 1972 sold in 1971. One bolt on the clip was different than the rest of the clip but was just as dirty as the rest of the frame and all.
Old 05-26-2014, 03:36 AM   #5
thelonerife
Hmm I dunno then.
Old 05-26-2014, 03:58 AM   #6
TrkEnvy
Maybe someone with an older truck robbed the discs and 5 lug off of it and put their old stuff under it to sell off the truck..
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline   Reply With Quote
Old 05-26-2014, 09:07 AM   #7
chopnchaneled
chopnchaneled's Avatar
YEP ! What trkenvy said.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 05-26-2014, 09:56 AM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
This is possible. ^
70 and older all had 6 lug with drums, and 71 and 72 were 5 lug with disc in 2wd 1/2 ton trucks
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-26-2014, 10:01 AM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Any pics?
Keith
Convert to disc brakes.
Old 05-26-2014, 01:51 PM   #10
mcrotty
Is it possible that its a late 1971 frame? I guess it doesnt matter. So I need 1970 and under spindles for disc. Then use five lug rotors . It cant be 1972 arms/ ball joints being drums right?
Thanks guys
Mike
Old 05-26-2014, 01:56 PM   #11
leftybass209
leftybass209's Avatar
In order to know what front end you have, I need to see your rear end! Haha what I mean to say is measure your rear end as they were different lengths for different years. Could give you more insight.
leftybass209 is offline   Reply With Quote
Old 05-26-2014, 01:59 PM   #12
mcrotty
I cant load pics right now. I can measure it right now. Flang to flang? Its six lug too.
Old 05-26-2014, 02:10 PM   #13
mcrotty
Rear measures 58 3/4 flang to flang. 12 bolt
Old 05-26-2014, 09:13 PM   #14
seafoam68
seafoam68's Avatar
Sounds like a 67-68 frame with 72 sheetmetal. Lots of people swap front ends but if you got the vin from the door plate then that would mean the cab was also replaced.Unless it was a vin switch-a-roo also. I've known many who swap later model running gear on a early model frame but never vise-versa. Good luck.
seafoam68 is offline   Reply With Quote
Old 05-27-2014, 12:54 AM   #15
mcrotty
The frame is 1972 with matching body and title. I guess someone just changed it over a one time. Again, I need 1970 and older spindles and parts?
Can I get 6 lug or 5 lug spindles for this truck?
Old 05-27-2014, 02:49 AM   #16
lolife99
lolife99's Avatar
Yes.
They make 63-70 conversion spindles.
Keith
Old 05-27-2014, 02:50 AM   #17
lolife99
lolife99's Avatar
I'm still not convinced. Wish you could post pics of the truck, the suspension and the glovebox SPID.
Keith
