Old 05-26-2014, 09:24 AM   #1
mafosa
oem gauge fitment?
hey fellas! im looking to rework my dash gauge assembly.
im liking the "new ole school " look of the OEM appearance. I have a universal " hot rod kit" wiring harness.
my question is. will the OEM gauges work with "new sytle" sensors? ie, fuel sender, oil pressure and water temp?
theres a vendor on here that refurbishes them close to new.
thanks inadvance!
larry
mafosa is offline   Reply With Quote
Old 05-26-2014, 08:54 PM   #2
ray_mcavoy
Re: oem gauge fitment?
No, you need to use "OE type" sending units that are electrically compatible with the gauges. Sending units meant for newer applications or aftermarket gauges typically have different resistance ranges that will result in incorrect readings if used with OEM gauges.
The 60 - 66 truck fuel gauges require a 0 - 30Ω sending unit.
The water temperature gauge originally used a GM #1513321 sending unit that is spec'd at 520Ω ± 20% @ 100°F and 81Ω ± 10% @ 220°F.
The oil pressure gauge is mechanical and does not require a sending unit. You will need a Weatherhead #6100x2 (or equivalent) threaded sleeve nut to connect 1/8" OD steel or copper tubing to the back of most GM mechanical oil pressure gauges.
ray_mcavoy is offline   Reply With Quote
Old 05-26-2014, 09:59 PM   #3
mafosa
ray_mcavoy, thanks for your great info. im not giving up on this. anyone, all ready do this?
larry
Old 05-26-2014, 10:07 PM   #4
cortcomp
cortcomp's Avatar
I've done this with other vehicles, use OEM gauges and sending units and new harness. Rule of thumb is match the gauges to sending units. If you swap out gauges, swap out sending units (unless new to new, old to old, etc).
You may end up modifying plug ends (one gauge takes bullet type connector, other spare, or another ring, etc.)
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 05-26-2014, 10:37 PM   #5
spacedebris
your looking for "original look" with "modern functionality" right?
I was reading an article that shows what some are doing. http://www.rodandcustommagazine.com/...auge_retrofit/
and it looks like they can help you out in doing so.
http://www.classicinstruments.com/in...ntID=retrofits
spacedebris is offline   Reply With Quote
Old 05-27-2014, 07:42 AM   #6
mafosa
thanks for all your input guys! more options then I thought.
larry
