Coolant overflow tanks?
What one is a good fit for 47-54 radiator?
What coolant overflow tank are you using? How about some pics? Thanks, Frank |
Re: Coolant overflow tanks?
I'm using a 800ml Rockstar energy drink can mounted inside a BMX water bottle holder
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
I used to have one of those plastic aftermarket ones from the parts house but I think this time I'll have my son weld me one up out of a piece of scrap stainless tubing. I might even use a piece of 2 inch exhaust pipe and paint it black to hide it a bit.
Using the plain looking, plastic, aftermarket one. Would like to fit a cool aluminum tube one, but really like to be able to check my coolant level at a glance when I open the hood.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
![]() Join Date: May 2007
I am going to use the original one on the firewall, and see how it works.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
in my 58 i have a piece of 304 stainless exhaust tube capped on the ends
3/8'' ss half couple welded in for a hose barb. couple of tabs to screw it to the inner fender. end caps are cut out of flattened tube. works, holds enough ![]() ![]() polished it and then hid it under my radiator cover ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
for almost the same price as the cheap plastic ones (that don't really fit), I found this on Ebay. It worked perfect...
This is exactly why I'm going to use a plastic one. I have several, none of which fit like I'd like them to. But, I haven't made it to a pick-and-pull recently and I know that there's one out there for me!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Great suggestions!
Thanks for the pics also. I do like the idea that a plastic one will allow me to see the level at a glance. |
My chevy 51...... http://67-72chevytrucks.com/vboard/s...d.php?t=541148 www.knutselracing.nl |
if you are using a aftermarket radiator like i am, and running a external trans cooler, you can use the unused trans cooler in the radiator. seen that and it looke really clean.
Not sure there's room for this in an AD but here's mine. I got it at Pull-A-Part out of a Ford van for $4. It met my requirements of cheap, easy to mount, visible water level, and left room for the A/C hoses below it. Not show but then nothing else about my truck is either, LOL.
#13 |
You need an overflow tank with a crossflow radiator but why use one on a downflow at all? Just keep the water level about at an inch down from the cap. The only time it would spew water would be in an overheat situation. I'm just going to run a tube down the side and call it good.
#14 |
#15 |
They do have to vent to work right.
I'm going to run one simply because there is a chance that it might build up enough pressure in slow traffic like being in line to get into an event and puke and on mine that ends up coming right up through the louvers even when the hose is on it right and shoots down towards the ground.
#16 |
Old Heap Driver
Here's mine, and yes, it does work properly, I can see the fluid going back into the radiator as things cool off.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#17 |
Those are the ones I use on my A D's.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#18 |
Don't mess with my PBR..... Gotta love it!
#19 |
Old Heap Driver
Thanks, I have a co-worker that keeps me supplied with "Coolant Overflow Tanks". LOL
#20 | |
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 06-01-2014 at 01:41 PM. |
#21 | |
[quote=Lextech;6700741]
13'' long tank, 16'' long vent tube. angle cut and stuck in to the top of the tank then bent to avoid spewing on the frame
#22 | |
[quote=_Ogre;6701803]
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
#23 |
