Old 05-26-2014, 04:22 PM   #1
1987chevyv10
Tube thing on manifold
Hi, do any of you know what this tube is coming off the manifolds on both sides of the motor? 1987 350 tbi
1987chevyv10 is offline   Reply With Quote
Old 05-26-2014, 04:37 PM   #2
csdineley
csdineley's Avatar
Re: Tube thing on manifold
It's for the air injection. Part of the smog pump system.
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's
csdineley is offline   Reply With Quote
Old 05-26-2014, 06:17 PM   #3
1987chevyv10
Okay thanks. I got a set of headers without anything to connect to it so can i just get rid of it?
Old 05-26-2014, 06:19 PM   #4
csdineley
csdineley's Avatar
Depends on if you need to pass emissions in your area.
Old 05-26-2014, 07:01 PM   #5
1987chevyv10
I don't have to pass emissions. So i'll be fine just to cut the hose off and put the headers on?
Old 05-26-2014, 07:10 PM   #6
csdineley
csdineley's Avatar
Shouldn't need to cut it. There should be a rubber hose that connects the metal manifold pipe to the pipe that runs behind the motor. Once the manifolds are unbolted should just pull off. (At least that's how mine was). I also removed the smog pump when I installed my headers.
Old 05-26-2014, 08:33 PM   #7
1987chevyv10
Okay thanks, need to do anything special to get rid of the smog pump? Like other than just unbolt it? I don't have my truck at home at the moment to check
Old 05-26-2014, 08:54 PM   #8
csdineley
csdineley's Avatar
Just unbolt it, and remove the belt for it.
