Old 05-26-2014, 09:36 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Acumalator Cover
Has anybody ever tried to cover the AC acumalator up to see if it helps cooling any better? Just wondering. How about putting hose insulation over the hoses to help also. Just wondering if it would make any differance, the newer vehicles have it so just pondering!
The picture is of a muffler cover but should fit over the acumalator with some work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-27-2014, 12:23 PM   #2
ERASER5
ERASER5's Avatar
Re: Acumalator Cover
That covering is more for sound than anything. The refriferant has already expanded and passed thru the evap core. The acumulators job is to catch any liquid that may have formed and keep it away from the compressor. oiling is the secondary but also important job of the acumulator.
OEMs are looking to quiet everything. Ford move the low pressure cut off switch from the acumulator ( the best place for it) to the line because you could hear the switch make and break. The rubber will also control sweating and the appearance of rust. Another thing OEM like to hide.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-27-2014, 02:10 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Acumalator Cover
Well I covered mine with some black insulation foam to see how it does. I guess if nothing else it will help it from condensating. I didn't wrap the lines but may just to help heat transfer on them.
Old 05-27-2014, 02:54 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
The accumulator is exposed for a reason. It is the last place that the refrigerant can pick up any amount of heat and ensure that the freon is in a true gas form as it goes to the compressor. The compressor can pump a gas, but a liquid will sooner or later take out some mechanical part inside it, since liquid does not compress. It would be my recommendation to not insulate the accumulator and make it inefficient in it's design. The liquid refrigerant is supposed to be down stream of the condensor and not before the compressor.
Refrigerant cycle= Accumulator-gas, compressor-high pressure superheated gas, Condensor coil-gas change to liquid, thermal expansion valve- liquid metered at small liquid laden amounts to evaporator cooling coil, Cooling coil- heat is absorbed from inside the cab to make a gas again, accumulator- collection point after the evaporator coil to boil off the last of the liquid to ensure a good gas is sent to the compressor.
Just my .02, as a refrigerent jockey from the past.
Frank
piecesparts is offline   Reply With Quote
Old 05-27-2014, 02:56 PM   #5
truckdude239
truckdude239's Avatar
i see them on alot of gms wraped up include some ford about all its good for is causeing the accumultor to rust out
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-27-2014, 07:44 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: Acumalator Cover
OK then I guess I'll take it all back off. You talked me into it.Well at least it didn't cost me anything other than a few tie wrapps.
Old 05-27-2014, 07:47 PM   #7
piecesparts
Most accumulators are made of aluminum, to allow for maximum heat transfer.
Frank
Old 05-27-2014, 08:09 PM   #8
truckdude239
I know our company truck was a 97 ranager and it was wraped up and the bottom rusted out i forget that most gms where alliuman
David fuller
2000 Tahoe 5.3l 378
Old 05-27-2014, 08:44 PM   #9
Andy4639
Old member
Andy4639's Avatar
Mine is aluminum also!
Old 05-27-2014, 09:36 PM   #10
truckdude239
Then it on there!
David fuller
2000 Tahoe 5.3l 378
